1999 Ford Mustang Cobra Logo
Posted on May 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 ford cobra wont fire has been in storage for 2 years put new battery in it still wont fire up under 2000 miles on it
Anonymous
Level 2:
Scholar:
  • Expert 63 Answers
  • Posted on May 03, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
63
Questions
Helped
19108
Points
196
You need to remove all of the fuel from the tank and lines, then replace with fresh fuel. Today's gasoline, especially those with any percentage of Methanol in them will not stay in storage very well past 6-8 months, sometimes less in bad weather conditions.
  • Mike Raatz
    Mike Raatz Oct 16, 2013
    Also reset the emergency fuel shut off switch in the trunk and the fuel pump fuse. During the initial start up you may have had a higher than average amp draw by the fuel pump to re pressurize the fuel system.
2000 Ford F-150 PU Turns over but wont start
Does it have spark an fuel pressure ? How many miles does it have on the odometer ? No Start Diagnostic Basics EricTheCarGuy
Recently blew a head gasket on my 2002 Elantra which I bought in Oct. 2001. Am I still covered for repairs?
10-YEAR/100,000-MILE POWERTRAIN PROTECTION Covers repair or replacement of powertrain components (i.e., selected engine and transmission/transaxle components), originally manufactured or installed by Hyundai that are defective in material or factory workmanship, under normal use and maintenance. Coverage applies to original owner only, effective with 2004 model year and newer model year vehicles. On 1999-2003 model years, coverage applies to original owner and immediate family members (i.e., wife, husband, daughter, son, stepdaughter, stepson).
Second and/or subsequent owners have powertrain components coverage under the 5-Year/60,000-Mile New Vehicle Limited Warranty. Excludes coverage for vehicles in commercial use (e.g. taxi, route delivery, delivery service, rental, etc.).
5-YEAR/60,000-MILE NEW VEHICLE LIMITED WARRANTY Covers repair or replacement of any component manufactured or originally installed by Hyundai that is defective in material or factory workmanship, under normal use and maintenance.
The following components are covered for time and mileage limits indicated:
• Radio and audio systems (i.e., radio, compact disc player, DVD player, navigation system, and Bluetooth®): 3 years/36,000 miles
• Paint: 3 years/36,000 miles
• Battery: 3 years/unlimited miles (100% covered 2 years/unlimited miles; after 2 years and within 3 years, 25% cost of battery and 100% labor cost covered)
• Air conditioner refrigerant charge: 1 year/unlimited miles
• Adjustments: 1 year/12,000 miles
• Wear items: 1 year/12,000 miles (e.g., belts, brake pads and linings, clutch linings, filters, wiper blades, bulbs, fuses)
2000 accent diesel wont start after headlights
hi may i suggest you have alternator output /charging checked also considering age of vehicle ? if origional battery ? have the battery checked for charge storage it may be failing to hold charge which would explain the problem you mention regarding use of h/lights slows starter rotation ?
1helpful
1996 Cobra Mustang surging or loping wont run right, missing
You should check the engine coolant temprature sensor (ECT).
1helpful
2answers
Try to start my 2001 ford focus want start everything else works the lights the radio etc
i have replaced coil pack. wires plugs on a 2000 2.0 sohc ford focus..and it still has no fire.... motor just turns over.. 99'000 miles i had the timing belt and all replaced about 10'000 miles ago at ford dealer ship.... what might be my problem now crank sensor??? all fuses i checked they are all good.... it just spins no fire to plugs so it seems...
1helpful
3answers
Hyundai 2001
I HAD THIS PROBLEM WITH MY ACCENT 2000 TURNS OVER FINE BUT WONT FIRE TURNED THE LIGHTS ON AND WILL START, SOMETHING ELECTRICAL IM ASUMING
Charging system
change your battery cables and check all wires on the alternator for loose connections, expecially the grounds.
3answers
2001 F350 Charging problems
actually the only thing i can recomend is to have the alternator replace again for warranty and before starting the truck charge the batteries very well with a baterie charger make sure to charge them individually because with a low batterie the alternator has to put a lot of load and might burnt again
specially with dual batterie.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
