Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
I have a Kitchenaid Superba Microwave/Oven combo. I would like just 2 tones at the end of the cycle, but so far my only options have been either 'all tones' or 'no tones'. In fact, the manual I have, does not even mention anything about been able to turn the tones off or reduce the volume. I had to do much online searching because the 4 loud tones every minute demanded that I drop everything and attend to it first. Real headache! Anyone has any suggestions?
ginko
  • 19396 Answers
SOURCE: Kitchenaid Superba 27 built-in Microwave/Oven
Disconnect it from power outlet for 30 minutes to hard reset the owen. It may be a faulty control panel or the fan thermistore switch.
Posted on Apr 02, 2008
SOURCE: kitchenaid superba oven
Hit the options button and check that the "Sabbath mode" setting is off. I note that October 20th was a Tuesday but the internal clock year could be incorrect.
Posted on Jan 18, 2009
  • 6 Answers
SOURCE: KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Posted on Jun 30, 2009
SOURCE: Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Posted on Jul 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchenaid Superba electric convection oven not preheating right
Your temperature sensor is failing. Replace the temp sensor.
Posted on Jul 21, 2009
I have a kitchenaid KEMc308 Superba Electric oven and micowave combo. Just had the light &door spring replace. Now, it gives code F2 E0 for 60 second and then give code F2 E1. I checked the key...
If you're searching for an obsolete keypad for a Kitchenaid Oven/Microwave unit, FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order.
Feb 02, 2015 | KitchenAid Ovens
My kitchenaid superba double oven in not woring at all after the self clean cycle finished. top oven door will not open, no lights on, nothing happens when I push buttons
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | KitchenAid KEBC107 Electric Single Oven
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Jul 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
KitchenAid Wall and Microwave Oven Combo - KEMS308SSS
Have had this oven for 8 years. At least three times, usually after using the clean cycle in the main oven, the latch mechanism has broke and the oven door will not open. In March they installed a 'new design' to prevent this. It's seven months later, and it broke again. Has anyone had similar experiences? How did you resolve?
Aug 27, 2008 | KitchenAid Architect® KEMS308SSS Stainless...
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
206 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
