Question about Linare Desktop, AMD Sempron 2200,40 GB HDD & 128 MB RAM
I have a Gateway 5200X that just stopped working. When I plug it into a power source the light comes on and the fans start running and within 15-20 seconds it shuts off
  • 2,404 Answers
Take out the battery and only hook up the AC Adapter. Then try turning it on. If that doesn't do it try just one memory stick at a time in each slot one at a time and turn on the laptop after each reseat.
If those steps don't work then take out the DVD drive and turn on the unit. If that still doesn't work then go ahead and take out the hard drive. If the machine stays on then you know the hard drive is the culprit. If the laptop still turns off then that means the motherboard is bad and would need to be replaced.
Posted on May 03, 2010
I have a 2004 Gateway 5200x computer. I can no longer change the background except for the color, the lists of background is frozen.
Then you have a copy of windows and not the original. I had same problem. Microsoft changes it until it doesnt go on anymore.
Dec 29, 2009 | Gateway 5200X PC Desktop
Gateway 507gr wont power on but looks like ps unit is good
Make sure you are plugging in your P.S. to Motherboard properly. This can happen if you are off by one pin on a 20 pin Supply on a 24 pin Motherboard. If you never opened the case and it just started happening, maybe one of your cards came out of its slot or your CPU Fan is not running.
Nov 06, 2009 | Gateway 507GR PC Desktop
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at gamecrazy944@yahoo.com or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
Older Gateway system not showing video...
is the system generating any beeping sounds when turned on ?, does the CPU fan comes on also ? do you anything on the screen such as teh gateway logo flashing ? IT coul dbe very well a bad power supply, try looking for a similar power supply usually should be no more than $40 or $50.
Jun 03, 2009 | Computers & Internet
Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Apr 26, 2009 | Gateway 500GR PC Desktop
Will not turn on
Try the following:
Check that power supply is plugged in to a live source.
Certain models had an additional power switch on the power supply itself. This would be located to the rear of the computer within 3-4 inches of where the power cord plugs in. Make sure it's on.
Press the power button on the front panel.
Press the space bar. The computer may be in sleep mode..
Gateway desktops usually have a small 'reset' button on the front panel. Press it.
If it still doesn't respond, I'd need to know a little more info before moving forward.
  • Are there any lights lit? (K/B, front panel)
  • Can you hear a fan?
  • Does the monitor turn on?
  • What (if anything) has changed since it worked last?
  • What was the last thing you were working on?
  • What model is it?
  • What steps have you taken so far?
Mike
Jul 11, 2008 | Gateway Computers & Internet
Computer won't boot up...
booting files corrupted try to boot by inserting windows 98 bootable cd or windows xp bootable cd
Dec 03, 2007 | Gateway GT4016 Desktop PC
Computers & Internet Logo
44 people viewed this question
Top Linare Computers & Internet Experts
Carlos L. Burgos
Carlos L. Burgos
Iqbal Husain
Iqbal Husain
spy1309
Are you a Linare Computer and Internet Expert? Answer questions, earn points and help others
