Question about HP Computers & Internet
Can not get printer 6180 to print any red colors
This printer will not print red colors
    Problem Solver:
  • 16 Answers
Try changing the red toner cartridge. Alternatively, try cleaning the gold contacts where the cartridge connects to the printer. Check that there's nothing in the way.
Posted on Dec 15, 2008
Clean printheads on Xerox phaser 6180
This type of print quality defect shows up if you have loaded the wrong type of paper in your machine and didn't remember to change the paper type (plain paper, card stock, labels, etc.).
This can also happen if the paper has a high moisture content, or if the humidity in the room is too much. Also make sure the room temperature is within its normal operating range (not too hot, not too cold).
The problem you describe could also be caused by using non-Xerox toner/drum units. Compatible toners don't work very well in Xerox printers.
Aside from those problems, the only other thing would be if the Fuser Assembly is near the end of its life...it will also cause some print quality problems like you are describing.
Dec 24, 2013 | Xerox Phaser Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
I have been printing photos and they have come out beautiful. Suddenly the colors are all muted, and brown hair has a green tint. My printer is an HP 6180. Nothing has changed - same paper, ink...
It sounds like one of the colors is not printing correctly. I would suggest , opening your hp solutions center programs and under tools you will find an option to clean the print heads. Follow the procedure to cleans the print heads, after cleaning open control panel on the computer and depending on the operating system click on "printers" (XP) or "devices and printers"(vista win7) right click on your printer( hit your right mouse button) select " printer properties" click on print test page. This page will print out showing each of the colors separately. You should see black, blue, pink and yellow. If one of these colors is missing or muted you will now which color is cratinging the issue. And at that time I would try changing the corresponding ink cartridge. Hopefully the print head cleaning will resolve your issue
Feb 11, 2013 | HP Photosmart C6180 All-In-One InkJet...
Why does my xerox phaser 6180 run out of cyan so quick
The 'STANDARD' capacity cartridges are only 2000 pages.
HIGH capacity are 6000 pages.
Mar 05, 2012 | Xerox Phaser 6180N Laser Printer
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
6180 will not print black text
Are you using genuine or knock off inks?
Take out the blabk cartridge and knock in onto your hand while using a paper towel to absorb ink.
If ink comes out you have a communuication problen with the printer ink carriage or a defective cartridge.
Jul 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have an HP 6180 that works fine except the colors are WAY off -- everything is muted and dull and the blacks are very weak. I've tried everything in the print dialogue box -- switching to application...
Bugger! HP wants your printer to work, so you buy more ink! Mine works beautiful
Scan a good photo and print it out or insert SD card and print photo on PHOTO paper GLOSSY SIDE DOWN Inkypete
Apr 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
Mar 27, 2009 | Xerox Phaser 7750DN Laser Printer
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
Computers & Internet Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
