Question about Garden
Need to replace small tube running from pump up bulb to Fuel tank, Where can I get the tube? Craftsman Brush whacker 31cc weed eater
  • 64 Answers
Most lawnmower shops. possibly hardware store.
Posted on May 03, 2010
Fuel tubing to pump up carb.
-Try to swap to the other one it there are two lines.
Good luck
mai
Dec 06, 2017 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Any help with mercury outboard motor
Replace the fuel line from tank to bulb and from bulb to engine. The old type lined tube gets damaged by the ethanol content in pump fuel. Buy non ethanol fuel if you can. The lining come away from the walls of the tube and blocks the flow. You can force it with the bulb, but the fuel pump is not strong enough to open up the lining. Your problem is becoming a common occurrence. The worst stuff is the grey tube apparently.
The other obvious thing is to make sure the vent is open on the tank and working, but engines will normally run for a few minutes unless you have a metal tank.
Take a look at these images, then click on the 'All' tab to get ethanol resistant fuel line.
ethanol resistant marine fuel line Google Search
Jun 17, 2017 | Garden
I have a craftsman chainsaw 2.2 cubic and there are 3 fuel lines two comming from the primer bulb and one going from carb into the motor or crank. The return is connected to a nipple on the crab and the...
This is a common problem. The fuel lines can become brittle and fracture, or sometimes they swell and will not stay on their connections.
The tube that connects between the carburetor and motor is likely used to pulse the fuel pump that is internal to the carburetor.
The primer pulls the fuel through the carburetor drawing the air out. As the primer is stroked first air than fuel is pumped out of the carburetor. The output of the primer returns to the fuel tank. That fuel line appears to have failed or become disconnected in your craftsman. Either the hose has broken at or near the fuel tank, or has pulled out of the tank. There is a small hole in the tank for many machines. The hole is smaller(providing a seal) than the tube diameter requiring a minor force to squeeze the tube back in place.
Look for the fuel feed tube that also connects from the fuel tank to the carberator. Any loose connections will allow air into the carberator and it will not beable to run.
Important is that the fuel feed tube can not be switched with the return tube from the primer. Connected inside the tank is a fuel filter that protects the carberator from contamination.
Hope this helps?
Jun 28, 2017 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
There are two outlets on the primer bulb for fuel mine rotted away while my son had it . I need to know which tube goes to where when i replace it.
Ok...follow these instructions closely and you will know.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
May 17, 2011 | Garden
How to replace the fuel primer bulb and fuel lines in McCulloch 3516 chainsaw? the fuel primer bulb broke and the plastic lines have crumbled. i need to know how to run the lines from the fuel tank to...
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Dec 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I bought a Poulan PPB100 at a yard sale for $20.00. I got it home and got it started and running but it leaked gas like no tomorrow. I took it apart to see what was needed and found that all the fuel...
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Please vote on this solution.
Aug 28, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Replacing fuel lines on ryobi weed eater,need
Jul 10, 2010 | Craftsman Garden
Cratsman 40cc chainsaw will not run. i get it started and pull the throttle open and it wants to die, sounds like it starves for fuel. put new line from tank to carb, blew out carb, dont no settings for...
A quick test to see if it's running too lean (starved for fuel) is to gently push the primer bulb. If the motor spins up (revs), it's likely a clogged high speed jet. If it stalls immediately, then it's running too rich and you need to cut back on the high jet.
See http://www.repairfaq.org/samnew/lmfaq/lmadjc.htm for some quick and dirty (but good) instructions on adjusting the jets to fine-tune your engine.
As for the primer tube, if the bulb pulls fuel and fills up when pumped 3-8 times, then things are fine. If the bulb never gets fuel, then you may have identified a potential cause (missing tube).
Jun 01, 2010 | Garden
Need manuel to show how gas lines are run to carb. & pump bulb
HOW TO CHANGE FUEL LINE ON McCULL0UGH 2014 CHAIN SAWS.
I have successfully changed the input fuel line by purchasing Tygon tubing from a local lawn equipment dealer. I did not see the box he cut this from, but the tubing I bought measures 0.190" outside diameter. I gave him a piece of the old tubing and he matched it up. A 18 inch piece cost me $1.19.
The routing of the fuel line involves three pieces, one piece from the fuel priming bulb to the carburator is 3 inches long, a piece from the fuel priming bulb to the gas tank is about 4 inches long and the piece from the fuel tank is about 7 inches long. The priming bulb sucks air and fuel from the carburator and dumps it back into the gas tank. Therefore, when you press this repeatedly, gasoline will eventually appear in the bulb when the gas line to the carburator is full of fuel. The bulb may not completely fill, there will always be a little air in the bulb.
The fuel line in has a filter on the end within the fuel tank. If you find this has broken off, as I did, you have to turn the tank upside down and shake the filter and any pieces of broken fuel line out of the tank.
Replacing the fuel lines within the carburator compartment is easy if you remove the carburator first. To work on this you must remove the two screws holding the carburator to the engine. You may need to use a small screw Torx driver, although on my chainsaw, there was also a long straight slot on the head. The line from the priming pump to the carburator goes to the left hand line on the carburetor (as viewing from the top with the blade extending away from you. The input line will go onto the right line on the carburator.
The two lines into the fuel tank are located in the middle of the tank left to right and one about 1/2" above the other. The upper hole is for the fuel intake line. The fuel line passes through this hole and a second hole visible within the tank fill hole.
This was the trickiest hose to replace. How I did it was to use a piece of #12 copper electrical wire stripped out of its insulation. This was fed through the 7-inch Tygon tubing piece until it emerged from the far end. I also found it necessary to put a bull nose end on the Tygon tubing in order to get it to feed into the tank hole visible from the tank fill hole. Why? I don't know, but after 20 minutes of trying to feed the hose (both naked and with the electrical wire inside) into that second hole, I gave it a bull nose on the tubing by careful cutting with sharp scissors and using a sanding block. Perhaps McCullough has a special tool to do this, but a call to their 800 number could not get a knowlegible answer from the parts person.
After the Tygon tubing shows up in the tank fill hole, I pulled it further with needle nose pliers and was able to pull the copper wire back out of the tubing. I then cut the bull nose lead I put on the Tygon tube and installed the filter onto it. I found that a little oil on the nozzle and the carburator lines makes the tubing easier to slip on. The stuff the filter and Tygon tubing back into the tank fill hole and towards the front end of the tank so that it drops into the bottom portion of the tank. After attaching the intake line to the carburator, use the needle nose pliers to pull excess line into the tank.
Reassemble the carburator to the engine and you'll be good for another 10 years of happy chainsawing!
Apr 01, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
232 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
