Question about Epson Stylus 880 InkJet Color Printer
All the warning lights are flashing on my printer how do I get it working again? I pressed the ink check button for the 3 secs and now it will not move on to be used as the lights just keep flashing.
  • 111 Answers
This usually means there is a paper jam of some sort. I would triple check to make sure no pieces of ripped paper are stuck in the rollers or are visible.after doing this, shut the pc down and the printer as well wait a few minutes start the printer and then the pc. if the lights are still on, verify that one of the ink cartridges had not become loose. this also happens when you forcefully move the printer head back. good luck
Posted on May 03, 2010
Why is alarm light flashing? 5800
The ink absorber is full,The waste ink error is based upon time instead of actual volume in the tank. You can reset the counter by the instructions below.
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the STOP/RESET button, then press and hold the POWER button.
(3) Release the STOP/RESET button, Next press and release the STOP/RESET button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the STOP/RESET button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Dec 18, 2015 | Canon PIXMA MX310 All-In-One Printer
After replacing the ink cartridge printer still shows cartridge levels at 0%
Hi
You have to reset the cartridge
To Reset the HP Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Release power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the indicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Thanks
Aug 15, 2010 | HP Office Equipment & Supplies
Replaced ink cartridges but monitor still displays "ink low".
Hi, this fix worked for me (i've been wasting few hours on mp150 the first time, so if it soesn't work at the first attempt, don't give up and try at least few more times)
  1. Power off the printer
  2. Hold the stop/reset button then press and hold power (for 5 secs)
  3. Hold Power and release the stop/reset button
  4. Press the stop/reset button twice
  5. Relase power button
  6. Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  7. On the 3rd press the inicator should be orange.
  8. Press the power button to set data
  9. To set data remove cartridges then replace
  10. leave for 20 or 30 secs
  11. Press the power button again to shut down
  12. Then press power button to power up.
  13. The printer will feed one piece of paper through then set language and counrty.
Then ink should be reset.
Good luck, Peter
Aug 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
All lights are flashing
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
All the best Pineworks
May 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Pixma mp150 E5 flashing and b + c flashing and warning light on! have recently put in cartridge world inks but have already printed with them now its playing up each time you try to use printer.
Canon printers MP 160 AND MAYBE OTHERS
it.
procedure:
button pressing
the "service mode"
Try it
it.
Mar 17, 2010 | Office Equipment & Supplies
My epson 1400 printer doesn't print
try printing a nozzle check to see if the nozzles are clogged by dried inks that why nothings printing. turn off the printer than press and hold power and paper button together for 3 sec. then release, it will print, if blank, all nozzles are clogged. do a head cleaning. hold the ink button for 3 seconds. wait until the power light stops flashing then print nozzle check again until all lines are complete,
Feb 10, 2010 | Epson Stylus 1400 InkJet Photo Printer
How do I reset printer after putting ink cartridge in
To Reset the Canon Cartridges Works 100%
Relase power button
Please rate my rsponse!!
Jan 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Reset To551 ink cartridges
  • Power off the printer
  • Hold the stop/reset button then press and hold power (for 5 secs)
  • Hold Power and release the stop/reset button
  • Press the stop/reset button twice
  • Relase power button
  • Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  • On the 3rd press the inicator should be orange.
  • Press the power button to set data
  • To set data remove cartridges then replace.
  • leave for 20 or 30 secs
  • Press the power button again to shut down
  • Then press power button to power up.
  • The printer will feed one piece of paper through
  • then set language and counrty.
  • Then ink should be reset
Please rate my sesponse!!
Thanks, SF
Jan 28, 2010 | Office Equipment & Supplies
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Refilled, full ink cartridges, but...
Relase power button
Aug 17, 2008 | Canon MX300 Office All-In-One Printer
Epson Stylus 880 InkJet Color Printer Logo
123 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
