Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Water filling up when off
Water filling up slowly inside when timer is in off position
  • 141 Answers
May be inlet valve be defective kindly replace the inlet valve even if you find that same problem exist the problem with the motherboard of the washing machine kindly give to expert to do the service
Posted on May 03, 2010
What would cause the inside of dishwasher to slowly fill with water even in off position.the water drains just fine, but after drained it will slowly start filling the bottom of dishwasher back up.
the water control solenoid unit has a faulty diaphragm in it allowing water to pass even though the power is off
replace it or turn the tap off after each use
call a technician for the proper diagnosis and repair
Jan 28, 2017 | Dishwashers
Switched timer to 53 mins. Machine runs with water trickling instead of gushing. It runs down slowly to 40 mins and then shows 4W (which is Error)
sounds like a bad inlet valve or screens inside the inlet valve are dirty, the valve is located wher the fill hoses hook up at
Nov 18, 2010 | Samsung Washing Machines
WATER IN WASHER WONT SHUT OFF
Hi and welcone to FixYa. I am Kelly. When water wont shut off no matter what you do the problem is inside of the water valve assy. Usually there is a small bit of debris in the diaphram center hole that is holding the water passage open.
Here is what you can try to do to clear if BEFORE replacing the eater Valve.
1. Get a bucket
2. Turn off both water supply hoses momentarily
3. Set the water temp to warm
4. Remove ONE hose from the wall connection and place the hose in a the bucket.
5. Turn on the remaning connected hose/
6. Start machine fill cycle and tap the hose connection at the water valve on the back of the machine with either a screw driver or hammer handle.
Timer OFF
REVERSE HOSE CONNECTIONS ON THE WALL CONNECTION.
7. Place the other hose in the bucket
8. Start Fill cycle.
9. Again tap the hose connection at the water valve
10. Stop timer.
11. Reconnect both hoses and test for water flow with timer off.
12. Start fill cycle
13. Rapidly select hot and cold wash water.
14. STOP fill cycle.
15. Remove each hose individually from the water valve one at a time.
16. Use a knive blade and remove the inlet screen from the water valve. Wash screen under slowly running water rubbing it clean with your fingers. Re install screen. Reconnect water hose.
17. Repeat step 16 for opposite hose and screen.
18. Turn on water supply.
19. Test for proper filling and water stopping by starting and stopping fill cycle.
If it works you got lucky. If you still have the problem you will need to change the water valve. Either one of these water valves will work on your machine:
http://www.repairclinic.com/Appliance-Parts?s=t-PAV2300-%3d%3dc292d509361
Thanks for using FixYa.
Kelly
That is about it
Jun 05, 2010 | Maytag PAV2300 Top Load Washer
Washer won't advance to next cycle. I think the problem is with timer. It works when I advance the timer manually. How do I change the timer and what is the part number? I have Whirlpool SAQS800HQ. ...
It may not be the timer,before you go down that costly road,check the water supply and see if it is filling through both valves or it could be a heater fault.
Is it filling slowly or draining slowly check.
May 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The freezer bottom slowly filled with water which froze.
the unit is not defrosting due to open heater element ot bad timer
Feb 22, 2010 | LG LFX25960ST Stainless Steel French Door...
Wptg9350c profile harmony washer- hot water slowly fills washer
That is not normal. Usually this happens because of a faulty inlet valve or because of a faulty control/timer board. The inlet valve is tested first and eventually replaced.
If the valve is ok , then proceed in testing the timer board.
Apr 17, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Delonghi HMW2400T oil filled radiator with no operating manual
if the timer is working when it gets to the off/on position you will hear a click so to test it just turn the timer around slowly until you hear the click much like an alarm clock that has the alarm turned off hope this helps regards Jim
Apr 14, 2009 | Heating & Cooling
Bosch Exxcel Auto option
There should be a float switch inside the dishwasher sometimes these get hung up on the full position which in turn keeps the solenoid from allowing the water to come on. remove the bottom rack and check to see if this is the case. Dislodging the float should fix the problem. If not listen to see if the solonoid Clicks when you turn the cycle to fill position if not it could be either solonoid or the timer. if you hear click and still no water check strainer in water line could be clogged or water is turned off some where.
Oct 19, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher problems
The washer may be attempting to run dry. Many times on these washers, a person may open the washer and then go to another load. The washer gets stuck with a dry pump until the timer tells water fill valve to open. Easy test. Start on regular cycle ,slowly advance the timer. it will click until you here the fill start and water will fill until.....
Jul 06, 2008 | GE Dishwashers
Fills with water
replace the water fill valve assy not hard at all
May 24, 2008 | Whirlpool GHW9250M Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
