Question about Kitchen Ranges
Oven doesn't heat
Frigidaire Gallery series gas range model # FGF379WJCB doesn't heat up properly and at times not at all. Seems to vent all the heat out onto the stovetop when it is heating. Gets orange glow from the bottom of the oven, but when I try to preheat it, it often never heats up, sometimes does heat after an hour of preheating, and sometimes smells like gas is leaking. Have tried heating it up by running the broiler then selecting bake temp, but that doesn't hold heat..it just cools off gradually. Broiler works fine, stovetop works fine.
  • 2 more comments
  • joescheff May 04, 2008
    My oven does the same thing. I can see the glow but no heat in the oven for over an hour on preheat. What is the part number to replace the ignighter?
  • bodywraps Nov 19, 2008
    bought my FGF379WJCB not long ago and it too has an oven tempurature thing going on, doesnt always heat up and if does is slow to. quite annoying when there are 20 friends over for baked dinner and you have to call kentucky ducky! Broiler works. will try the igniter change scenario
  • LeeS23 Apr 20, 2009
    I have the same symptom with the same stove. One question I have, though, is that with mine, the oven will eventually heat up to, say 400, and display that temperature but if I turn the oven off then then on again, the actual temperature will be much lower. This seems more of a temperature sensor problem than an ignition problem. Was your's the same?
  • Anonymous Mar 23, 2014
    after resetting the time due to day light savings time the oven and broiler does not work. Checked the heat elements they checked good. On the digital display I select oven and select the temp, the lights show oven working and it clicks showing preheat, but the elements never heat up.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Posted on Mar 26, 2008
SOURCE:
Directions how to use self cleaning over on the fridge re gallery gas stove
Hello, Joan -
Clarification: You are asking about a Frigidaire Gallery model gas stove and how to use the self-cleaning feature for the oven? If so . . .
You will find the instructions here:
https://www.hunker.com/12002208/instructions-for-a-frigidaire-gallery-series-self-cleaning-oven
If you need the user manual for your oven, you can add the model number by choosing Comment and adding the information there, so I or someone else volunteering to answer on Fixya.com can look for and provide the right link for a download of a free manual.
Note: There is more than one Frigidaire Gallery range model numbers made:
https://www.frigidaire.com/Kitchen-Appliances/Ranges/View-All/?filter=Feature02012:Feature02012
Best wishes.
Apr 06, 2018 | Kitchen Ranges
Gallery series Frigidaire gas oven not heating up correctly
Hello Hilda, thank you for your post!
There could be a number of
any one of several underlying causes in why the oven is experiencing this
particular issue:
·Convection
heating element
·Thermal cutout
·Thermal oven
sensor
·EOC
(electronic oven control)
·Ignitor,
·Bake or broil
element
·All wired
connections
·Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat.
The parts above will need to be assessed for further evaluation by a technician since it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Aug 29, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
I have a frigidaire gallery range that is slow to ignite when the oven is turned on and when it does ignite it"s slow in reaching the set temperature. Also there is a smell of gas.
You would definitely want to seek out a professional technician to diagnose the unit. Gas units are very dangerous if you are not use to working on them. You could have a slow gas connection or flow, a faulty valve, or bad ignition. All would absolutely need a professional to diagnose and repair, this is not a typical DIY job.
Dec 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not heat up
most likely you have a bad ignitor,if it glows and it doesn't ignite the flame within 40 seconds the ignitor is bad.just because it glows doesn't mean it's good.
Dec 12, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Vent below clock puts out alot of heat
That is the oven vent and it will throw alot of heat when the oven is on... that is very normal operation...the oven needs to be vented to for various reasons...
This can be a great benefit in the winter time but is very uncomfortable in the summer...so limit the summer use and use it like crazy in the winter...
heatman101
Sep 14, 2010 | Frigidaire Gallery 30" Self-Cleaning...
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
977 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
