Question about Brother MFC 240C All-In-One InkJet Printer
The magenta ink is not printing though is full of ink and is ok, may be the tube is not doing well
  • 24 Answers
Because of the way that ink cartridge is designed, it is possible the end where the ink comes out of the cartridge is plugged up.
When you first open the ink up from the package, there should be some protective seal or tape covering the whole that needs to be removed. If you have already removed this, then it sounds like the ink cartridge is defective, so you will need to contact the vendor where you purchased this ink to get either a refund or replacement.
Hope this helps! :)
Posted on May 03, 2010
    Genius:
  • 1,354 Answers
Are able to see the printer icon on your screen next to the taskbar if yes then open that there will un printered list will the just cancel the all jobs
after that it will be work properly
My C7250 will not print with the Magenta or light magenta ink.
Ok, try holding * and push # then when it asks for the special key combo, enter 1 2 3
This will enter a service mode on your printer, there are numerous menus in there for performing service options. I would suggest going to the resets menu and try doing a semi-full reset. This will wipe all the settings from your printer and restore it to
Sep 29, 2016 | HP Photosmart C7250 All-In-One Thermal...
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
HP CM1015 - stil works; Magenta does not print even though full
The magenta might have been freezed, change the magenta.
Thanks.
Jun 19, 2012 | HP LaserJet CM1017 MFP All-In-One Color...
Epson 9800 ink magenta not printing after power cleaning
The separate print head is to blame. Needs replacement. Not cheap.
Aug 31, 2017 | Epson Stylus Pro 9800 InkJet Printer
HP Designjet 110 inconsistent printing of magenta
>Check ISS pumping, >Check ISS tubes is there air gap?>Check cartridge bag broken in side?>Check for leakage at cartridge bank & carriage assm.>Do the following force priming to fil ink in tubes as well as in print heads:****Hold the power button down and press the cancel button three times and the resume button three times.****Switch Off the printer and then On again in order to start the priming of the ink supply tubes.
Jan 04, 2012 | HP DesignJet 110 Plus NR InkJet Printer
HP Z6100- Magenta ink density fade
there may be air bubble in ink tube assembly if u can do the priming then ok o/w call hp service provider to do this
Jul 28, 2010 | HP Designjet Z6100 InkJet Printer
Failure to print from computer in colour
I have a similiar issue that just started happening recently - the printer shows FULL inks but the PC thinks it has empty inks. I tried the * #, 123 reset hardware failures, but that didnt help. Printer run self diagnostics says all is fine....
I am using USB connections - and this has been fine for years, until now. Maybe a microsoft patch issue?
Jul 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
When I calibrate colour Magenta and Lt.Cyan fail to print
boil the head printer in a hot water for ten minutes and wiped it smoothly
Aug 09, 2009 | HP DesignJet 130NR InkJet Printer
Can I print "Black only on the Epson BX 300 F ?
Since the printer insists on having all 4 cartridges (non-empty) fitted before it will print anything, the only recourse to fitting new cartridges is to fool the printer into thinking your empty magenta cartridge has ink in it. You can do this by using a cartridge resetting tool to reset the magenta cartridge chip so it reads "full". A resetter tool can be obtained from e-bay very cheaply (£4 or less). You will find sellers who ship worldwide on E-Bay UK.
Be aware though, that if you forget to select monochrome printing, the colour ink is also used in black printing - and printing with a "dry" cartridge can damage the print head. You can guard against this by filling your magenta cartridge with distilled water.
You will also find sellers of magenta cartridges (and the others of course) on E-Bay UK who ship worldwide.
Feb 25, 2009 | Epson Stylus C86 InkJet Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
127 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
