Question about Motorola Mobility H700 Wireless Headset
Bluetooth problem; need i.d. number/code
I have a bluetooth H700 that has worked previously with another phone. I am trying to pair it with my new phone but can't get past the i.d number, as i don't know where i have placed the box and info. Can you please help!!!!!
    Genius:
  • 1,019 Answers
Try 0000
Mike @ compurepair.
Posted on Mar 26, 2008
SOURCE:
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
I just bought a bluetooth and my son put a random pin number and now i cant get acces to my device
Your headset will indicate it is in pairing mode when its indicator light is steadily lit in purple. Open the headset boom. If it has never been paired with any bluetooth headset before, it will enter the paring mode right away. If it has been previously paired, make sure the bluetooth radio of that(those) device(s) are turned off, and after some 5 to 10 seconds, you'll see it is in pairing mode.
Now, on your phone's bluetooth application, delete the H700 from the list of paired devices (if it is there, that is), and make it search for new devices. After a while, the H700 will show on screen. Select it and command it to proceed. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, you can download it from this location.
Hope it works for you.
Cheers! Carlos
May 16, 2010 | Motorola Mobility H700 Wireless Headset
Connecting h700 headset to cellphone
Now, make your phone's bluetooth application search for new devices. After a while, the H700 will show on screen. Select it and command it to proceed. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
Cheers! Carlos
May 08, 2010 | Motorola Mobility H700 Wireless Headset
Pairing my bluetooth
the solution was to replace my phone.i found out that it had been damaged by a previous owner.
Mar 21, 2009 | Motorola Mobility H700 Wireless Headset
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
H700 unable to pair up 'service not supported'
The term "service" refers to other types of services supported by bluetooth technology like keyboards, mice, etc. There's a lot more than just headsets now. I suggest checking the bluetooth options on your phone to see if there is a refresh service or other option....there is one like that on my blackberry that I once had to use to solve a similar issue. Have you tried disabling bluetooth, rebooting phone, enabling bluetooth, and rebooting phone before pairing? Also, look to see if there is an encryption on/off option on the phone...this could be causing an echo in either state due to interference...try switching encryption on/off. Also, check your update options on the phone, you didn't say which kind of phone it is but some can get firmware updates that may be needed for bluetooth to work well. Finally, you may get results by deleting the device on the phone and re-adding it thru discovery.
Jun 23, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
23 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
