Question about Sony STR-DE185 Receiver
Can I play ipod (or connect my laptop) on/to Sony str-de 185?
  • etseytlin May 04, 2010
    I had doubts how it will work. Thank you for your help
  • 10,594 Answers
You can hook audio output of your laptop to this receiver with RCA to headphone cable, plug RCA pins in any free input of receiver and plug headphone jack in audio output of your laptop, make sure minimize volume level of laptop on volume control (speaker icon at lower right corner) select input of receiver and play some music file in laptop to get sound.
iPod docking is necessary to hook iPod with this receiver.
Hope this info will help you.
Thanks.
Posted on May 03, 2010
How can I use digital media port adapter TDM-iP50 with an older Sony STR DE 425 receiver's RCA inputs? Is there a conversion cable--dm port to RCA?
The dm port Can't you just pull the audio from the iPod from its analog headphone jack with an adapter? They're common and cheap.
Dec 29, 2010 | Sony STR-DE425 Receiver
I have the sony: STR-DE 685. The sound in the
This sounds like a very poor connection. Please make a new splice on speaker and receiver. This should take care of this for you.
Feb 26, 2010 | Sony STR-DE597 Receiver
Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Feb 13, 2010 | Sony STR-DE445 Receiver
How do I connect my ipod to my Sony STR-DE585 receiver
Use analog audio cable with jack connector on one side (to the iPod) and 2 RCA connectors (white/red) on the other end for the analog inputs of receiver.
Feb 07, 2010 | Sony STR-DE585 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Input from IPOD - I want to play music from my IPOD through my Sony STR-DE1075. I have an IPOD line out adapter. cannot figure out which input I should be using.
Any input as AUX , DVD or Tape will work fine ..whichever you connect.and/or available...But please do not ever use the "Turntable" input...make sure volume of IPOD is half way open as listening earphones not max..good luck..
Jan 07, 2010 | Sony STR-DE1075 Receiver
Want to play my ipod through sony str-de135 receiver
Get a headpone to rca cable (radio shack or best buy) and use any input on the rear of the receiver except phono. You will need to turn the ipod to near max volume.
Nov 28, 2009 | Sony STR-DE135 Receiver
Getting the best out of my Sony STR DE-475
Yes, it would downgrade.
Simply run an HDMI cable to the LCD from the DVD player. Now, use the digital audio output of the DVD player to run to the receiver. I know the Sony has an optical input which i recommend over the coaxial input as the optical cable doesnt waste any energy as a medium transferring sound since its only light.
Mar 29, 2009 | Sony STR-DE475 Receiver
Playing ipod on sony str-de595 receiver
You need a 3.5mm mini jack coupler lead with phono plugs on end plug one end into your headphone output on ipod and phonos into your amp lead must be stereo
Dec 22, 2008 | Sony STR-DE595 5-Channel Amplifier
Sony STR-DE185 Receiver Logo
128 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
