Question about LG 24 in. LDF 7811 Built-in Dishwasher
When I push the START button, it makes its normal 3 tone sound and then the "delay timer" starts flashing 2 "E's", and just dings. None of the other buttons will light up when I press them.
  • kasowski May 03, 2010
    Hey Rylee,
    I checked all the hoses. There doesn't seem to be any kinks or blockages. I shut off the breaker to the dishwasher for 15 minutes. It is hardwired in so I couldn't unplug it. Still getting the same issue. Any other suggestions or has something in the kleypad gone bad?
    The far right digit is like a backwards 3 or an E. The next digit to the left of the backwards "3" or the "E" is another backwards 3 without the top line. How's that for a Polish answer!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Although there is no 2 ‘Es’ error code for this unit. However, this might be due to kinked hoses or some other electronics issues. To narrow down the problem please unplug the dishwasher from the power socket and mains and re plug it after 15 minutes. Now disconnect the power source to your dishwasher before you conduct any test. Either unplug the unit from the wall outlet or flip the appropriate breaker in the circuit breaker panel and access water inlet valve. There will be one hose feeding water from the house to the water valve, and another hose leading from the water valve that carries water away. Now inspect dishwasher's hoses to make sure they aren't responsible for any water flow problems. Make sure the hoses are securely connected to the valve. Also check to make sure there are not kinks in the hoses. Kinks can impede the flow of water. If still the issue is not resolved, then it means the key pad might have gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 03, 2010
  • Rylee Smith
    Rylee Smith May 03, 2010
    Please post back with exact error code for further assistance.
  • Rylee Smith
    The error can only be fixed by following these ways:
    Replace the connections of Hose.
    Check the point of damages and repair or replace the related parts.
    Replace the Impeller of the Washing Pump.
    Thanks
    Rylee
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Set clock and be able to tell am from pm setting
The Clock uses a 12-hour cycle with a.m. and p.m.
1. Check that the oven is off.
2. Press CLOCK.
3. Press TEMP/TIME "+" or "-" arrow pads to set the time of day, including a.m. or p.m.
4. Press CLOCK or START
The Timer can be set in hours or minutes up to 12 hours and 59 minutes.
1. Press TIMER.
2. Press TEMP/TIME "+" or "-" arrow pads to set the length of time.
3. Press START to begin the countdown. If enabled, end-of-cycle tones will sound at end of countdown.
4. Press TIMER twice to cancel the Timer. Do not press the CANCEL/OFF keypad because the oven will turn off.
5. If the TIMER is running, but not in the display, press TIMER to display the countdown for 5 seconds
Delay Start:
The Start Time keypad is used to enter the starting time for an oven function with a delayed start.
Hope this answers all you questions about your stove.
Jaye
Nov 04, 2013 | Whirlpool RF263LXTQ Range
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 | LG WM2016C
My b2300 bread maker wont start on the 15 min delay after i push the start button .......why? i hate this machine and wont recommend one to anyone.......love my old sunbeam machine which just broke down...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 19, 2011 | Black & Decker B2300 Bread Machine
I have been using a Sunbeam Model 5891 Breadmaker for over a year without trouble. Today I loaded the machine like always and selected the settings I usually set and hit go. Nothing happened. The lights...
The Sunbeam 5891 is a disposable type for there are no user-servicable parts.
Here's more:
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Jun 17, 2011 | Sunbeam 5891 Bread Maker
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
Stove/Oven/Range timer sound not working
Hi before buying a new control, did you try turn the tones on? Here is how you turn them on and off:
Tones are audible signals that indicate whether a function has
been entered correctly, or when a cycle has ended.
To shut off all tones except the end-of-timer and error
tones:
1. Press and hold the STOP TIME button for 5 seconds.
2. A short tone will sound when the tones have been changed.
To turn tones back on, repeat step 1.
3. “OFF” will be displayed for 3 seconds when the tones have
been turned off, and “ON” will be displayed for 3 seconds
when the tones have been turned back on.
May 03, 2010 | Kitchen Ranges
Wiring a dayton timer relay
If i understand you correctly you want to push the button, release it and have the timer give power to the solenoid for 3 more seconds, correct? If this is the case you will need an off delay timer. On delay timers work like this. You push the button, power goes through the timer, at this point the timer starts counting, when the timer reaches its preset point,(3 seconds we'll say) the contacts change till the power to the timer goes off.
If you hook this up with an on-delay timer this is what will happen:
Push the button and release, the timer will tick as long as you hold the button down, till three seconds, then the solenoid will raise until you release the button.
With an off delay this will happen: push button , solenoid begins working, when button is released timer counts 3 seconds while solenoid is still working, then removes power to the solenoid.
The way you would wire the off-delay is like this:
Connect line side of your pushbutton(incoming power side),incoming power and terminal 1 on your base together. next connect the load side (outgoing power side) of your pushbutton and terminal 2 on your base together. Connect terminal 3 to the hot wire or terminal on your solenoid. Lastly connect terminal 7 the incoming neutral wire and the neutral wire or terminal of the solenoid together.
I am telling you how to wire it in my head, if you'll write back with some specifics such as what wire you will use, where your getting power from,what the solenoid current draw is and such i can get a little more detailed. maybe it will make more sense.
Also make sure the timer and pushbutton are rated to handle the solenoids running current. The timer appears to handle 10 amps im not sure what you pushbutton can handle. Also keep in mind the solenoid will operate for whatever time u set it to, after the button is released. There are other ways to do it but this would be the most economical way.
And of course turn the breaker off and test that it is off before working on the circuit. Write back with any problems.
Apr 02, 2009 | Amperite Dayton Solid State Timer On Delay...
Dryer heats up but won't turn
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Nov 27, 2008 | Dryers
LG 24 in. LDF 7811 Built-in Dishwasher Logo
48 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
