Question about iRobot Roomba Scheduler 4230 Bagless Robotic Vacuum
Just purchased new battery....Used once and now won't charge
    Genius:
  • iRobot Master
  • 1,461 Answers
Check that the charger circuit is ok fuse fine....Sounds like no charge voltage, chck connections clean....
Posted on May 03, 2010
My 9.6v DustBuster doesn't hold a charge
Does the charge light come on when you plug in the charger? If not, the charger or cord is probably bad. If it seems to charge but you're not getting as much time as you used to, the battery probably needs to be replaced. Check your warranty and call dustbuster or go online to purchase a new battery. Another alternative, especially if it is out of warranty is to take the unit to a Batteries Plus store and have them replace the battery.
May 01, 2017 | Vacuums
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
I bought Dyson DC16 in 2008. Charged full but it only last for 1 minuet. Should I get a new charger? Is Dyson going to send me a new charger?
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Jun 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I have a unit that is about 4 years old and appears to NOT hold a charge. I know to only charge for 3 hrs max but want to be sure my problem is the $75.00 battery before I purchase one. What is your...
Mar 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Battery or ?
If this model is under 1 year warranty, I would suggest that you take it to a warranty repair shop or that you ask for a replacement. with a Return Material Authorization (RMA) at no further cost to you for shipping.
Jan 10, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Roomba 4108 does not charge
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
Dec 12, 2008 | Roomba Robotic Floor Bagless Vacuum
Won't charge
The battery from Lowes was the perfect solution for my Oreck AV-701B vacuum. In this vacuum, however, the wires are soldered to the battery leading to a plug which powers the vacuum. You will have to desolder the old battery and solder the new one. This is easy soldering and any friend with a soldering iron could do it for you in two minutes. The improved (restored) power is amazing.
Jan 04, 2008 | Oreck ElectrikBroom AV-701B Handheld...
iRobot Roomba Scheduler 4230 Bagless Robotic Vacuum Logo
189 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
