Question about iLO (2 GB) MP3 Player
Dead in the water
2 gb mp3 started out computer wouldnt read then it went to when it was connected to computer it would go to sleep or power off you had to take out the battery/put it back to get it to come back on now it will not power up or do any thing dead in the water help
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
SOURCE:
Pioneer Inno
Perhaps memory is full
Jun 23, 2008 | Audio Players & Recorders
Ipod wont restore caution sign with slash going thru circle, also itunes wont recognize ipod and try sleep mode dm mode nothing . plz help
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
second
let the battery run completely out not low... dead, attached to PC and Itunes
Jan 09, 2011 | Apple iPod classic 6th Generation Digital...
Doesnt turn on.
This same thing happened to me. I was playing fantastic contraption and my ipod screen just went black and wouldnt turn back on. When I plugged it in to a charger, it made that charging noise, but wouldnt turn on. SOLUTION: try holding in the sleep/wake(power) button, and the home button at the same time for about 15 seconds or until you see the white apple logo. That worked for me, hope you get it fixed.
Flaming Llama
Jul 04, 2009 | Apple iPod touch Second Gen (8 GB,...
My ipod wont turn on or charge.
More than likely the battery just needs to be replaced. I let my nano go dead and it was doing the same thing. So just get it replaced and that should fix your problem.
Mar 23, 2009 | Apple Audio Players & Recorders
ENGINE CRANKS BUT WONT TURN OVER
you meant its a NO CRANK engine.
silent starter, say the word silent.
even the starter relay must click.
and if head lamps die, so will be the starter.
due to a dead battery,
sounds like a bad battery to me. dead or only
DISCHARGED.
if the Charge/battery lamp is off in the cluster driving. its ok. the alternator.
starter car with the jumper cables connected
and not next day.
only live jumps matter. or you go know where.
if you want to walmart they have tool there that
tests the alternator
battery
and for phantom drains all in 6 min work, the tool does all the work.
if the battery is charged, it will crank I bet
its discharging.
for 1 of 3 reasons.
1: its bad.
2: the charge system is dead.
3: phantom drains, it goes dead as you sleep
the head lamps dead is the big clue there.
Mar 19, 2017 | 2002 Jeep Grand Cherokee
Pc turn off and k5 is dead
you over charg3d it which mean you kill3d the battery.
Nov 28, 2008 | Samsung YP-K5 MP3 Player
I have a sansa 4 gb and after a few songs it starts to skip or cut out.
You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
player automatically when it is playing for a certain time.
1. Press Menu button to return to the Main Menu.
2. Move to Power and select it.
3. Select Auto Power Off or Sleep.
Nov 07, 2008 | SanDisk Sansa Clip MP3 Player
Screen frozen cannot turn player on or off
Well, mine was frozen, and wouldnt respond to anything i was doing. so it wouldnt turn off. I let it stay on all night, but in the morning i went to it, and it was dead, so i went and plugged it up to charge, once it got a little battery, I turned it on, and it worked perfectly fine. try thisss(:
Jul 23, 2008 | Insignia NS-DV2G MP3 Player
MY ilo mp3 player will not start unless it is connected to a computer.
i fixed one recently that wouldnt turn on like yours, a part on the inside broke off and i resoldered it. if you dont mind, you might open it and have a friend whose good with electronics look around and see if anything is loose, disconnected, fried
Sep 30, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
26 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
