Question about Brother MFC-9440CN Laser Printer
Part number for fuser unit? - Brother MFC-9440CN Laser Printer
  • 24 Answers
This is what I show: LR1962001
Hope this helps! :)
LR1962001
LR1962001
LR1962001LR1962001
Posted on May 03, 2010
  • funkyagain
    funkyagain May 03, 2010
    Not sure why it posted that part number so many times... Sorry about that. Should just be: LR1962001
  • funkyagain
    wow... thanks for giving me the 1 thumbs up bud. your so dumb
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
How do i change sleve of hp 2300dn ?
the sleeve you are referring to is the Teflon sleeve located in the fuser unit and is covers the upper heating element in the fuser unit.. unless you are familiar with fuser rebuilds don't attempt it.. you can purchase rebuilt fuser units or brand new OEM units From Precision Roller Part number is RM1-0354-050,or RM1-0354-000
Apr 24, 2014 | HP LaserJet Office Equipment & Supplies
Hot error shown when we plug fuser...
you have the wrong type of fuser - probably HP 4200/4300or 4250/4350. these units look IDENTICAL the correct fuser unit assy part number is RM1 1044 a small white barcoded sticker should be present with the part number on the base plate of the fuser unitt
Jan 16, 2014 | HP LaserJet 4345mfp Printer
Fuser unit voltage, old 110, new 220 can this be right
HI are you in the usa or the u.k. ? If its the USA, 110v, if its the U.K.220v is the right one , Markus.
Jan 11, 2014 | Samsung CLX 3160fn All-In-One Printer
Part number brother 9840cdw fuser
Part# LU4103001
About $150
The service manual will be hard if not impossible to find. They only release those to factory authorized service centers. If you just need it for the fuser replacement instructions then often those will be either in the operators manual which is easy to find or the instructions will be in the box that the fuser comes in.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
Require part number for complete fuser unit.
there are two different fusers for that machine depending on the model you have here are the of the numbers and models so you can pick the one you need
831A00V-R702-00 FUSER UNIT 120V MODEL 2500
831A00V-R703-00 FUSING UNIT 220-240V MODEL 2500
Oct 28, 2009 | Konica Minolta magicolor 2550 Laser...
Engine Fuser Low Heat Error
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Cory
Nov 04, 2008 | Samsung CLP-510 Laser Printer
Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
Fuser Assembly Unit for RICOH Aficio MP 6500 Printer
This part number B2484582 is modified.
The new part number for the fusing unit is B2484583.
Yes, you can find it from a Ricoh Supplier.
Good luck and please rate me, thanks.
Jul 06, 2008 | Ricoh Aficio AP2000 Laser Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
Brother MFC-9440CN Laser Printer Logo
186 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
