Question about Logitech LX6 Mouse
Left-click functionality For buttons and tabs that require one click ('approve' or 'yes/no'), my new LX6 is requiring a click (which highlights) and then another click (which performs function). It's doing the same to "x" out of a program or to highlight an email in my inbox - one click (which does the equivalent of 'select' the item) and then another click to perform function. I've checked in the settings and, while they appear relatively simple, I cannot figure out what I've done incorrectly here...thank you!!
  • 221 Answers
SOURCE: My Logitech cordless mouse MX 700 is being eratic.
There could be a sensitivity problem with the mouse before installing new drivers and software you can try going to the mouse settings to see if there's an adjutment problem,
  • click on the mouse icon in the control panel
  • a mouse properties box will pop up
  • at the top of the box click hardware
  • look to see if your mouse is labeled under devices.
  • highlight your mouse it should say, this device is working properly.
  • you might want to go through all the mouse settings first to make sure there set right, pointer's activities, pointer option's, ect, if your still having problem's here's a link with the software and driver download for your mouse,http://www.logitech.com/index.cfm/398/&cl=us,en?prodcrid=398
also replace the battery if it's low, good luck.
Posted on Mar 30, 2009
LythKross
  • 150 Answers
SOURCE: Greetings: I'm moving a marble mouse to a new
I believe you would have programmed the buttons with the driver software that SHOULD have come with the mouse. That would be your best bet. Look to see if the drivers installed a utility to program that mouse buttons.
Posted on Jul 06, 2009
SOURCE: TrackMan Marble LTC54203304
- - I just followed the directions ! - - Thanks for your help. - - Fred
Posted on Oct 27, 2009
SOURCE: Logitech V450 Nano Cordless Mouse Left & Right Click Problems
I have the same problem.. Is that you have sims 3 installed?
Posted on Jun 20, 2010
Mike258
  • 1498 Answers
SOURCE: Loss of control over my mouse.
Hi Arsenal,
My Logitech cordless occasionally does the same thing. On mine it was caused by a build up of gunk over the optical sensor. Once I cleaned it, it functioned normally.
I know it doesn't make sense as far as the buttons. I'm just sharing what worked for me. Hope it works for you.
Best regards
Mike
Posted on Jul 29, 2010
Error code 0303 HP laptop, I bought a new hdd same problem to be sure that the hdd is good I installed it on my other laptop asus g53sx and works great, no problems. For some reason HP dosen't like it.
The 303 error would indicate a failing Hard Drive, but try the following first and then re-run the HDD test - if it still fails, it would look like you'll need to replace the drive.
Click the Start Menu, click Computer, left click Local Disc C once to highlight it, right click Local Disc C and select Properties. Click the Tools tab and then click the button to 'Check the Drive for Errors'. In the following window make sure both boxes are ticked and then click Start. Part of this process will require a restart to check the drive.
Oct 30, 2013 | Computers & Internet
Unlock mouse intel core 15
depending on your laptop this will vary
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option.
Click on it and you will see the option to enable your device, then click OK
or
Right-click on a blank spot on your desktop. Scroll down, select "Personalize" and then choose "Mouse Pointer."
Click the "Device Settings" tab. Highlight your TouchPad in the "Devices" section. Hit the "Enable" button.
Click the "Apply" button and then click the "OK" button.
or
Click the "Start" button in the lower-left corner of your computer.
Type "mouse" in the field above the button. Click "Mouse" in the list of items that appear.
Click the "Device Settings" tab. Highlight the touchpad item in the "Devices" list.
Click the "Enable" button. Click the "Apply" button and then the "OK" button.
hope this helps
Sep 25, 2012 | Intel CTL E09L 2goPC Laptop
How can i activate my mouse sensor???
or
or
hope this helps
Sep 24, 2012 | Acer Aspire 5102WLMi PC Notebook
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
How do I enable my touchpad scrolling feature?
Right-click on the desktop, then click "Personalize."
Click "Change mouse pointers." This opens the mouse properties window.
Click the "Gestures" tab in the mouse properties window.
Click the "Use Vertical Scroll Function" and "Use Horizontal Scroll Function" check boxes.
Click "OK."
or you might
click "Start" button in the lower left corner of your desktop.
Scroll up and hit "Control Panel."
Choose "Mouse."
Highlight the touchpad in the list of devices. Hit the "Enable" button.
Hit the "Apply" button and hit the "OK" button.
to disable
Go to the control panel to the Mouse options and click on the Gestures tab and there is an
option that under Virtual Scrolling "Enable Virtual Scrolling" disable that option and that
should stop the auto scroll.
hope this helps
Sep 01, 2012 | Dell Inspiron 1520 Motherboard
A few weeks ago I bought an iMac, I've been using my LX6 without any issues and this morning it quit, cursor won't move and it's a fairly new unit. Changed batteries, hit the reset button and on/off. ...
open mouse folder inside control panel and check everything in all tabs.... definitely you have to work with keyboard to reach there , use tab and alt buttons to choose option,to check in acheckbox you have to press the alphabet which is underlined in a sentence near checkbox.
Apr 23, 2010 | Logitech LX6 Mouse
Connection error
Your antivirus' firewall may be causing this. Here is a link that could help you allow google talk from your firewall.
You can also do the following:
Add the Google Talk application (googletalk.exe) to the approved list.
Behind a proxy server that requires a proxy username and password? Follow these steps:
  1. Open Google Talk.
  2. Click Settings.
  3. Highlight Connection along the left side of the dialogue box.
  4. Select Use the following proxy.
  5. Tick the box next to Proxy requires Authentication.
  6. Enter the proxy username and password.
  7. Click OK.
Jul 26, 2009 | Google Talk
Flash error message
The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format.
You can also format the player in Windows Media Player tiself.
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
You may also want to check www.mymusix.com for any firm updates - the above procedures in some cases undo the original formatting on the player, and a firmware upgrade will be required to replace the Mp3 player's formatting.
-Tha Mp3 Doctor
Mar 11, 2008 | MyMusix PD-6030 MP3 Player
Flash error
-Tha Mp3 Doctor
Mar 08, 2008 | MyMusix PD-6030 MP3 Player
Fast forwarding
RCA TH1100 Series:
http://support.rcaaudiovideo.com/downloads.aspx?product=25
-Tha Mp3 Doctor
Sep 17, 2007 | RCA TH1101 MP3 Player
Logitech LX6 Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
