DISMANTLE PRINTER overflow waste ink pad
    President:
  • 4,070 Answers
Hi! You may need to replace the waste ink pad or may be just clean it till it dries up so that it can absorb ink and can avoid spills. Hope this helps and have a good one!
Posted on May 03, 2010
Ink pads end service life
Such an open ended question is difficult to answer but to cover the basics, here's your options:
  1. Take the printer to a service centre and ask them to replace the waste ink pads and reset the waste ink counter.
  2. Reset the waste ink counter using a compatible tool (specific information about your printer model is required to determine if one is available).
    BUT... if you just reset, be prepared for the waste ink pads to overflow and cause damage/problems.
  3. Reset as per 2. but also install an external waste ink tank like a Printer Potty kit.
If you want more specific information, please provide your printer model and we can go from there.
Jun 28, 2013 | Epson Printer
When printing coming on the screen "The Ink
When turned on, the printer initializes the cartridge, and perform inkcharge. So there is some ink discharged to waste ink pad. The printer calculates the amount of waste ink, and when the waste inkreaches a certain amount, which approached the waste absorptioncapacity pad, then the printer will stop printing command. Intendedto waste ink does not overflow from the waste pad. To be able to re-use the printer must be reset waste ink counter., and replace thewaste pad. Or it could also extend the exhaust hose to outsidebottle.
Jan 14, 2011 | Canon Office Equipment & Supplies
Waste ink error message where is the waste ink?
The waste ink is in a pad that covers the whole bottom of the printer, underneath the print engine. You need a shop to remove all covers and the printer and replace the pads. Once changed they have diagnostic access to reset the ink counter. You can find instructions to reset the counter but soon ink will overflow and ruin the printer and possibly furniture.
Apr 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
What does it mean when the power light and the printer light are blinking on an Epson c60 model?
If all the Led's/Light's are blinking/flashing on an Epson Printer, that indicates "Maintenance Request Error". The maintenance request error is actually a "Waste Ink Pad Overflow Error". Normally your remedy is to replace the Waste Ink Pads with a new ones and then reset the INTERNAL WASTE INK PAD COUNTER...The need to replace the waste ink pads is measured by the amount of ink uses, which is determined based on the number of Head Drive Pulses, accumulated in the waste ink counter. When the total quantity of ink deposited onto the waste ink pads, during cleaning and flushing, reaches the set limit, the printer generates a maintenance request error and stops printing. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.I know this information is not much help, but at least you will know what your ERROR is.
Feb 26, 2010 | Office Equipment & Supplies
Error Code 5 on Canon MP160 Printer
your problem is waste ink absorber is full,you need the canon mp tool which is use to reset the counter of your printer,but you must dismantle your printer to clean the waste absorber because if you will reset the counter without cleaning it, all waste ink will overflow on your printer.
Apr 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
C43 stylus does'nt print
What rotorcrafts omits to say, is that this has occurred because the waste ink protection counter was warning you that your waste ink pads are saturated with ink and should be replaced. If you don't do this, eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Feb 21, 2009 | Epson Stylus C43SX InkJet Printer
Epson stylus 830Uink pads full not printing help
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
http://www.mediafire.com/?m6ouftizois
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson C46 has stopped printing with message saying service needed but nobody wants to make it carry on working
If both printer lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
If you wish to pursue this matter further, report back.
Apr 12, 2008 | Epson Stylus Photo R200 InkJet Printer
228 people viewed this question
jasbo
jasbo
