Question about HP Photosmart Premium C309A All-In-One Printer
Windows could not start the spooler service on local computer when trying to connect hp c309a printer
  • 24 Answers
If you the print spooler isn't working, you can either manually turn it off and on by going into your control panel - Administrative Tools - Services - Print Spooler - Then click the restart button.
The other easy option which usually works is just restarting your computer. This will restart your print spooler as well.
Hope this helps! :)
Posted on May 03, 2010
Testimonial: "Thank You, tried that but still no good. I am on windows 7 premium 64 bit upgraded from vista home premium. The errors I keep getting are - the local print spooler is not running. On the description for spooler in Services it reads Failed to read description error code 15100"
Printer spooler service not running
The spooler is not on your printer it is in the Windows folder on your computer and is used to hold documents whilst preparing to print.
Normally this service is set to start automatically and there are a number of reasons why it may of stopped but try this:
Right click on "Computer" in your Menu and then left click on "Manage".
In the page that appears click "Services and applications" and Click "Services"
Navigate down to "Print Spooler" and double click on that line.
A box should appear showing properties of the Spooler.
It should show
"Startup Type = Automatic"
"Service Status = Running"
If neither of these are true then change the Startup type to Automatic
and click on the "Start Button"
The service will then either start or tell you why it cannot start.
Nov 21, 2013 | LG Computers & Internet
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
There is a print cue in my HP Photosmart C7200 series that will not cancel and it has my printer hung up.
In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Now Try to Print Will Work Fine....................
Good Luck :)
Sep 26, 2011 | Office Equipment & Supplies
I have a HP LaserJet 1018 ans it stopped printing. When i access the printer it says "Windows can't Add Printer. The local print spooler service is not running. Please restart the sppoler or restart the...
go to start->run and then type net stop spooler... hit enter
then type net start spooler .. and hit enter..
you may also go to run and then type CMD.. This will take you to the DOS Black screen.. here you may type SC CONFIG SPOOLER DEPEND= RPCSS and then press enter.
After this restart the computer and try to print..
Sep 07, 2010 | HP LaserJet 1018 Printer
Seem to have a document "stuck" in the printer queue. I have deleted it from it, it says it is deleting, but doesn't disappear, & the document that I really want printed, which is next i line on the...
U have to clean the Print Spooler. What is Ur operating system? For example. in Windows 7 U have to: 1. Start > Control Panel > Administrative Tools > Computer Manager. 2. Select Services and Applications > Services. 3. In column Services seek for Printer Spooler and select it with the mouse. 4. Click right mouse button and select Restart. It should solve the problem.
May 23, 2010 | HP Photosmart Premium C309A All-In-One...
Document in queue won't print.
Good Luck :)
Mar 03, 2009 | HP PSC 1315 All-In-One InkJet Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
HP C1480
Please perform the below steps to clear the queue and print from the computer.
Before performing the below steps try to make a copy from the all-in-one to check the hardware functionality.
Remove the USB cable from the computer.
Now click on start --> control panel --> printers and faxes --> right click on the HP C4100 printer icon and delete all the pending documents.
Now again click on start --> run --> type services.msc and press enter --> locate print spooler in services window and right click on the print spooler and click on refresh or stop the spooler service and then restart the spooler.
Now open the printers and faxes folder, right click on the printer icon --> properties --> advanced tab --> enable print directly to printer and click OK.
Now connect the USB cable back to the computer and then try to print from the notepad and check for the result.
May 29, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
HP Photosmart Premium C309A  All-In-One Printer Logo
542 people viewed this question
Seeker5211
Seeker5211
