Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher pykel original dish drawer
Beeping and displaying F2 code
  • kpcoetzee Nov 26, 2008
    i need to pull the pump out, how? :( Fisher & Paykel DD603SS DishDrawer or something simmiler -.-
    President:
  • Fisher and P... Master
  • 2,651 Answers
If you pull out the lower drawer, there s aside release pin on either side of bottom corner of hte drawers when extended. a small maybe quarter sized hole( no need to mess with that only removes the face panel) but under it is a release that you can push in and back a little, this will unlock from the drawer hinges(slides) just nee to lift up and over to the left slightly, on the back wall behind hte drawer youll find a pretty good trouble shooter for this model, itll tell you what hte code is and will try to walk you through as to what might of happened as well as recommended repair
Posted on Mar 26, 2008
My dishwasher fisher pykel twin dish washer model # DD 605 , SHOWS AN ERROR CODE f7 first then shows error code f9
The top dishdrawer is hard to open or close as the lid seal actuator motors are most likely faulty or lost power. The scraping is the lid seal touching the drawer lid. The F7 and F9 error are a result of this fault with the actuator motors.
At the base of the dishwasher housing under the bottom drawer is the power board. From there the power is supplied to the controller and the motors. These motors move the lid seal into position. First turn the mains power to dishwasher off and then back on. See if this resets the motor position. If not you will have to call the technician to fix the problem. But if you are technical savy you could go to the base of the dishwasher and take the connectors of drawer 1 out from the power board and swap with drawer 2 which is working.
If power board connection is not making any difference, then motors are the likely problem. Needs a lot of expertise to replace and adjust the motors.
Mar 23, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
No power top drawer
Try to reset your dish washer. Turn off main power supply and leave it for at least 1 min. Is there any error code appear/beeping sound?
Sep 09, 2007 | Fisher and Paykel 24 in. DD603H W Built-in...
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher drawer won't run, beeps F2 error code
Craig, we had virtually the same situation.  The repair man  came and it took 2 minutes to fix.  The problem was that the bottom drawer had not been used for a couple of years and thus the impellor had jammed.  to fix it take out the basket, lift off the rotor arm and unscrew the knob.  Then just work the impellor around with your fingers until it frees.  It then worked perfectly.  We will use the bottom often from now on to prevent this happening again. By now the left over pumpkin pie will be a bit green!!
Nov 29, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
FISHER PAYKEL DISH DRAWER U3 FAULT CODE
LP is a setting for Low pressure. To reset your pressure to HP, hold the Programme and Eco touch switches simultaneously for 5 seconds. Once the setup mode is entered a beep is emitted and
the LCD is red with ‘HP’ or 'LP' displayed. Push the Start/Pause button to alternate between HP and LP. and push the power button to exit.
Sep 14, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher & Pykel dishwasher dual drawer
I have the manual for your model here what are you asking ?? is there a fault you want to reset?? if so what is it on the display?/ I dont know what you mean by>> " he reset it" reset what the drawer ? [please be as clear as possiable..If you are mech incline i can email you the manual
Jan 27, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
120 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
