Question about Carrier 38CKC024 Air Conditioner
Not cooling very well and outside fan sounds laboured
  • laura Newman May 11, 2010
    Check your filters inside and clean/replace as necessary. Check your evaporator coil (coil at inside unit) and clean as necessary. Check your condensor coil and clean as necessary. If, after performing these steps, you continue to have problems, let us know and we will dig a little deeper. :-)
    President:
  • 1,515 Answers
Hi, this is a 2 ton split system by the numbers. If the condenser fan motor sounds tired, not knowing the age and if it has been serviced, you may be loosing the bearings. If the motor is not a sealed unit, you can see the oiler's on it and add a couple drops of 20weight oil. You can pick up this oiler at a hardware store with a teloscopic end to reach them. Also, pull the power plug at the outdoor unit and give it a good hose down on the coil. This will cause the head pressure to be high and all will labour. On the data plate you will see what the amps this motor draws, about 1.5 R.L.A. or so and maybe a 1/4 h.p. If you have excess to an amprobe you could check it this way, but most folks haven't. Clean the coil and careful not to bend the fins with to much pressure. This is a good place to start and get back to me. If the motor does not fail, you may be low on freon to. Keep me posted.
Sincerely,
Shastalaker7
Posted on May 03, 2010
Why won't my fan oscillate?
There is a little arm attached to the motor that makes the fas oscillate. If it gets disconnected you will have that issue. Check the linkage.
Feb 29, 2016 | Dyson AM05 Hot Cool Fan Heater
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
Why tempstar 5000 High Efficiency a/c outside fan won't turn off ?
Sounds like your contactor is sticking in your outside unit. They could be welded shut.
Jul 21, 2014 | Heating & Cooling
Trane XE 1100 outside fan works but no cool air in house
Without much to go on, it sounds like you have a leak and lost some charge. It could be many other things but this is a start. I would check to see if the compressor is running, and the indoor fan is running. Is the filter clean? Check these things first, and then call a contractor if they check out ok.
Aug 08, 2012 | Heating & Cooling
My computer is making noise from the fan
Some noise from a fan is normal with age typically. You can run a free program like speedfan to make sure it's not affecting cooling. 60-65 degrees C is not uncommon but 40-55 C is more normal temp. If the fan is causing you stress, you can have a repair shop replace it. It will probably set you back $100-150 parts and labour,... mostly labour. Some laptops will have an access panel on the back allowing for easy replacement, typically 2-4 screens and a small plug is all it takes to replace them.
Nov 23, 2011 | Computers & Internet
My goodman ac seems to be no cooling. i have new filter and drain line is vacumned. i changed a chip board about a year ago. the fan on the air handler is working. condenser is running outside. the...
is the compressor and fan running outside ? Is the large copper line going to the outside unit a little cool or noe at all ? Sounding like low on refrigerant.
Aug 19, 2010 | Heating & Cooling
I have a Ruud Heat Pump system. The outside unit makes a humming sound in either heat or cooling modes. The fan won't come on. In cooling mode, the compressor starts up, but them shuts off after about a...
Sounds like your condencer fan motor is stuck. Can you take a long rod and when the power is off to the outside unit, spin the fan blade? Maybe it will be enough to get it working again.
Apr 07, 2010 | Heating & Cooling
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Cooling Fan
sounds like to me your motor in your fan is going. that is y your 4 runner ran nice and cool when its cooler outside. the hotter it is outside the harder your fan will work
Apr 25, 2009 | 1995 Toyota 4Runner
Carrier 38CKC024 Air Conditioner Logo
67 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
