Question about Aloha Housewares 02044 Compact Heater
Airtech model 02931 heats up and turns off right away.
My airtech heater model 02931 heats up but turns off after a small amount of time. When it turns off I have to turn the thermostat all the way down and wait for it to reset.
I have an airtech fan heater model 02044. Is it possible to get a replacement remote control?
Only from the company that made the product, but we do not sell parts here.
Jul 10, 2017 | Dryers
Propane turbo heater. After awhile why does it start to burn eyes and nose?
Hi Eric
It sounds like the heater is getting the air in the room so warm that it's making your eyes and nose hurt. That can be from dryness, from heat, or from combustion products.
Depending on the partucular model, you can try to:
  1. Turn the set temperature down.
  2. Turn the turbo fan to a lower setting.
  3. Turn the feed valve from your propane tank to a slower feed. At some point, you should be able to throttle the amount of fuel burning in a period of time to where the heat is more bearable.
  4. If you're smelling fuel, or overt burning petroleum smells, turn the unit off. This is a sign that things aren't burning right.
Last, but probably most important. If you are running a unit like this inside, make sure you have windows open. Please take me seriously here - installed propane furnaces have heat exchangers to pull in fresh air, heat it, and pass that air into your house. A propane heater burning inside your house is burning your inside oxygen and, depending on the flame quality, dumping Carbon Dioxide or, worse, Carbon Monoxide, into your house. You can end up dead pretty quickly, especially from Carbon Monoxide poisoning, and you'll likely be feeling fine right up to the time you pass out. These types of heaters are meant more for outside use, so please, if you absolutely feel you must run it inside, keep windows open and have a fan running. You're playing with your health
Good Luck!
Nov 24, 2015 | Heating & Cooling
Room Thermostat--Right near heater
First move that fridge!! Constricting the airflow like that not only makes the heater cycle too much... it's a safety hazard.
Once you allow the heat to circulate properly you can address the issue further.
Oct 26, 2013 | Heating & Cooling
I have a very old toastmaster small heater model 2517. I use to have it at work to keep under my desk for heat on my feet. I want to give it to my son for his pop up camper. My question is, are these...
I have one in my motorhome. If it falls forward or backwards it will shut off. And if the red safety light comes on it has overheated so turn it off and unplug and let it cool down. After it cools down it will operate normally.
Feb 05, 2011 | Vacuums
I receive Lo H20 message at an air energy heat pump. Probable problems?
This is pretty common for LOW FLOW through the heater. Most of the time, homeowners turn the bypass the water away from the heater and this reduces the amount of water flowing through the heater. Check the bypass to ensure that you have enough water flowing through the heater.
There is nothing else that will throw this code unless the flow sensor is bad altogether.
Once you have inspected your bypass, and the code reappears, you will need to have the heater inspected and possibly change out the flow sensor.
Dec 07, 2010 | Jandy Air Energy Heat Pump - 100,000 Btus
I have a Nordyne heater modle #E2EH-017HA. The heater will heat up but the fan will not turn on. You can turn on the fan manually. Any idea what is wrong?
Some times they use a bi metal switch its silver metal about the sizze of a dime.
or they might have a fan relay on a circuit board a small black rectangular shape device.
Ihave even seen the solder connections break away from the relay pins.
Oct 08, 2010 | Heating & Cooling
I have a 1974 honda CB200 motorcycle and the right exhaust gets very hot while the left exhaust stays at a normal heat range. This happens within minutes of turning the bike on. Sometimes a small amount of...
Sounds like that cylinder is running very lean, which causes high heat. If you have multi carbs, get them synchronized right away, the high heat can ruin a cylinder/burn a valve.
May 20, 2010 | Motorcycles
Both fans turn on but no igniter or heat ?
If the igmitor doesnt glow it is probably cracked. If it
is a spark ignition or in both cases check for a flame rollout switch located ontop of the burners should
have a little reset button.
Next if that is tripped yhou need to find out why, vent
plugged or another source drawing air away from unit
Jan 20, 2010 | Star Enerco Heat HSU45 Garage Heater 45000...
No Heat - Electronic comfort system - Temp indicator flashes
something on the inside is resticting the air flow possibly paper!
Jan 15, 2009 | 1994 Buick LeSabre
Aloha Housewares 02044 Compact Heater Logo
104 people viewed this question
Top Aloha Housewares Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an Aloha Housewares Heating and Cooling Expert? Answer questions, earn points and help others
