Question about Homelite Carburetor Trimmer Blower 308054001 Mightylite
Homelite model UT21566 string trimmer runs only on full choke and at lower RPM. I have disassembled and cleaned carburetor but that did not fix problem. Steve
  • 21 Answers
Your carb high and low settings may need tweaking if it's not a fuel or muffler issue. I believe needles are made only to be adjusted by a technician. If you want to try adjusting it yourself, google and you tube your to see how.
Posted on May 08, 2010
I had the same problem for a year. I was using a MUCH larger diameter line than my 26vt called for. The first time I started it with the .080 line on it it ran just like it is supposed too!!!
Posted on Aug 21, 2011
Homelite gas edger cuts off after running about 10-15 seconds
The fact that is runs slightly longer on full choke may point still to a fuelling issue.. Does it actually Rev in those 10 seconds or does it just want to bog down and stall.?
May 18, 2016 | Homelite Garden
Homelite string gas trimmer Model ut20811A: 1. Will start with full choke and run with full choke for a while but will not maintain speed when choke is released. 2. String feed will not feed when taped....
If it only runs with choke on, then mixture is too lean or idle set to low.
Adjust mixture initially at 1.5 turns, then move in or out as needed for highest idle when warm.
Make sure no leaks or clogged filter when adjusting.
Hard to say with string feed, but are you sure you are not putting the spool in backwards?
Mar 12, 2011 | Homelite Garden
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
My Homelite trimlite trimmer will only run in the choked position. When I switch the choke lever to run it dies. What could be the problem
Could be a dirty fuel filter or cracked fuel line. The filter is usually inside the tank. You should be able to take the cap off and turn the unit upside down and shake it so that the filter drops from the tank. If not then grab it with a pair of needle nose pliers. If changing the filter or replacing the lines doesn't work, the carburetor might need to be cleaned.
Apr 18, 2010 | Homelite Mighty Lite Lawn Trimmer
Trimmer only works on full choke
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 20, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
My homelite trimmer model ut20006 will not run unless it,s on half choke. I think it,s the low speed jet but where is it and how do I get to it thanks
Jim
Jun 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite String Trimmer not firing.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Usea Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
Jim
Jun 15, 2009 | Homelite Garden
My homelite weed wacker will only run in the choke position
Check the fuel lines for breaks/cracks. If they are o.k. then you will need to clean the carburetor. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen in carb. is free of debris. Use a Den Tek Brush,(http://www.amazon.com/dp/B000V5MQ7Y/ref=asc_df_B000V5MQ7Y820727?smid=AKZ54EXMVZHXW&tag=dealt5228-20&linkCode=asn), to clean the small portals in carb. Reassemble and start.
NOTE: If your carburetor internal parts are more than 4 yrs. old, you may want to replace them. So buy a carb. kit.
Jim
Jun 10, 2009 | Homelite Mighty Lite Lawn Trimmer
Will not stay running .
You need to clean the carburetor. Disassemble the carb. and spray with carb. cleaner. If you need tip on how best to do this, just let me know. If after you have reassembled and tried to start, and it still does the same thing, you will need to buy a carb. kit and replace all appropriate parts.
Jim
Jun 01, 2009 | Homelite Garden
My mighty lite will start but it runs on full choke but it stops
Your carburetor needs cleaned you had old gas in it this cloggedup your jets and made the diaprams hard witch will not move enough to pump enough gas to keep engine running off choke.
May 15, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Carburetor  Trimmer Blower 308054001 Mightylite Logo
1,270 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
