How can i remove power password for toshiba l300-2cc
    President:
  • 524 Answers
Click Here to see how to remove power password for toshiba
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 03, 2010
How do I lock my Toshiba Satellite L500 laptop
You can put a Power On Password of your Toshiba, this will prevent unauthorized access to youe laptop. If you forget this password then you will have problems unlocking your Toshiba.
The Power on Password is configured in the BIOS under sercuity settings.
You can also put a password on the hard drive and if your Toshiba is stolen and they remove the hard drive out of your Toshiba into another laptop they cannot get access to the data on your hard drive.
NOTE if you forget the hard disk password you will not be able to access your hard disk.
Sep 01, 2011 | Toshiba Satellite L500 Series Notebook
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
Toshiba satellite l505d
unplug laptop and remove battery. Take out both memory sticks and locate on the motherboard under sticks two points marked with ***. Replace one memory stick, plug ac adapter back up and while jumping the two points at the *** (use paperclip, flathead screwdriver or other metal object to connect the points) power up computer. This, if done properly, will reset bios, removing password.
Jul 21, 2010 | Toshiba Satellite L505D Notebook
Toshiba Tecra a6-ez6311 Removing Power-on Password
Unplug and open laptop and remove BIOS battery and leave unplugged and this will reset BIOS.
Jun 03, 2010 | Toshiba Tecra A6-EZ6311 Notebook
Toshiba Satalite A215 Laptop Bios Password
remove battery.....wait for 3 minutes....put it back and turn on...the bios wii get reset.....
if it still didnt got reset, then you need to remove cmos battery in the board by removing the back cover....
Apr 20, 2010 | Computers & Internet
I forgot my power on password for my Toshiba Labtop
The power-on password cannot be removed -- this is a "security" feature to prevent a thief from using your lappptop, after stealing it from you.
Find the original sales-receipt, to prove that you are the owner, and telephone Toshiba, and ask them for assistance.
Nov 13, 2009 | Toshiba Satellite A135 Notebook
Lost power on password toshiba portege 4000
The only solution is to take the computer to a Toshiba Authorized Service Center to have the password reset. If you have registered ownership of the computer with Toshiba they will be able to help you for a fee.
Hope it helps.
Aug 29, 2009 | Toshiba Portege 4000 Notebook
Reset bios password in satellite 1135
remove the power cable, batter and the cmos battery from the computer, wait a couple of minutes and reassemble. The bios with the password will be reset.
May 30, 2009 | Toshiba Satellite 1135-S155 Notebook
How to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
May 27, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Password
If you are talking about the BIOS password then you are probably out of luck since many Toshiba's use EEPROM password storage which means you can't reset it by removing all power (CMOS Battery). If it is an XP Password look into Samurai Password Removal Tool.
Dec 18, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
