Question about Riso RZ220 Duplicator
Risograph RA4050 diplaying error code E11, anyone know what that means? Has recently been putting masters on the drum crooked and making grinding noise.
    New Friend:
  • 34 Answers
E11 is the pressure control motor encoder has nothing to do with the master problem it is most likely out of time. (grinding noise)
Posted on Sep 09, 2010
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Oct 20, 2012 | Washing Machines
Risograph pressure roller isnt coming up
Dust on paper exit sensor? (small hole between the exit belts)Sensor blocked or defective?
Sep 12, 2012 | Riso Office Equipment & Supplies
Risograph 3770 Drum problem
Seems the 'synchronisation' between paper feed and drum ist lost. Maybe you have heard a ripple sound? This means the toothed belt has jumped one or more teeth.Remove back cover loose paper feed clutch to readjust the belt accordingly ...
Sep 03, 2012 | Riso RP 3700
Error code E11 on hoover washer dryer vhw854d
Nov 12, 2010 | Hoover Washing Machines
I recently bought a used Riso RZ310 - It seems to be in operating condition. However, I didn't know anything about it, and when I pulled out the master drum it had a heavy film of ink on it... so ... not...
It is part of the copy process for the ink to be there, remove the old master and slide the drum back into the Risograph. And create a new master, you can find user manuals on the net, if you are unsure how to do this.
Oct 12, 2009 | Office Equipment & Supplies
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
E11 on riso gr 1700
When machine displayed E-11 it’s interrupted the operation.
Its means Pressure Control Motor Lock –
If the Pressure centering sensor does not detected on & off within 5 seconds from the start of the machine.
This problem is the engine of pressure, this is located by uncovering the back, more or less in the middle and bottom, there is a small motor that is attached by screw(s). When the machine is turned on its intial position should be detected and if not , the sensor can be bad or the starting position is dirty or broken cable, or motor cables are bad, inspect them, reset the code and turn the machine off and back on.
Dec 21, 2008 | Riso RZ220 Duplicator
Risograph Drum
Try run a hundred copies at slow speed and full density/ pressure.
If that fails get a can of WD40 and spray it under the master, then rub the area with your finger. this will desolve the dryed ink on the drum surface.
Dermot
Sep 09, 2008 | Riso RZ220 Duplicator
307 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
