Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
The engine starts but run for 10 sec. when add gas to carb.
Frist i had no spark, replace the coil , ran good for three days ,and then started 4 days later , runs for 10 sec. sounds like poping sound when runs.I did pull the head off to see if the valves were sticking,working good and change the plug, any answer?
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 88 Answers
With it backfiring i would guess the valves may need adjusting and if that does not help clean the carburator.
Posted on Sep 23, 2017
2 Suggested Answers
cool78259
  • 228 Answers
SOURCE: we have a 6.25 /Briggs & Straton we have cleaned
You should have two fuel lines going from the carb to the tank, one has a filter,
make sure both lines are good without any breaks or cracks. if the filter is dirty
you may need to replace it. you can fish it out of the gas tank by making a hook
on a wired coat hanger, try to remove the filter and put the line back in the tank
make sure they are both submerged, if it runs just replace the filter, good luck!
Posted on Jun 26, 2011
Ran day before, now why won't it start?
Hi, William and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Troubleshooting No Start Honda Motorcycle
troubleshoot motorcycle not starting
How To Get Your Motorcycle Up Running Randys Cycle Service
Dec 13, 2015 | GAS Motorcycles
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Start and ran the mower for 10 min Shut it down and now can't get it running for more than 10 sec. Changed the gas drain the old gas Changed the spark plug, cleaned the filter as stated. still can
Tecumseh engine right? Pull the float bowl off the carb. I suspect some water contamination. while it is off clean the jet holes in the nut. They may have varnisized gas in them. contact me with any more questions.
Sep 13, 2012 | Yard Machines Garden
How to fix a1998 buick century to start fuel filter new and airfilter turning over but not starting gets gas
Did you check for spark? It sounds like you're not getting spark. Check for spark. If you are not getting spark then it sounds like you might have to replace the coil packs. Is it running a L4 engine? If its running a standard chevy L4 its probably the coil packs. Try to replace them check again for spark.
May 25, 2012 | 1998 Buick Century
Cant get 5.5 hp Briggs and stratton to start after cleaning out fuel lines tank and carburator changed plug it ran for a sec then died again what now
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.~~
Jan 22, 2012 | Mtd Garden
Engine 5 hours old running like a clock ran out of fuel try to start next day no go has fuel and spark no kick plug and coilpack is good dead as a maggot . Can somone HELP!
Question, will it run on starting fluid? possible that gas is bad or carb has a blockage,especially if it ran out of gas-(all kinds of stuff in gas anymore)
Nov 11, 2010 | Garden
My 05 Yamaha Grizzly 660 will not start. In my limited troublshooting practice I looked at FUEL, FIRE and AIR. Here is the fault, the engine will not start. I checked wires/fuses, plugs, fuel lines and air...
Sounds like you have a stuck float needle in the carbs (2). Usually after a few days with gas in the carb they will free up, you could 'knock' on the carbs with the plastic end of a screwdriver to help free them up. If not, turn off fuel, drain the carbs and fill them with carb cleaner for 24 hours. Redrain, attach fuel lines and turn the gas back on. If still no start it's time for a rebuild...
Mar 05, 2017 | Yamaha 2005 Grizzly 660 Auto 4x4
No spark. Have a '91 S-10 4.3L. Drove to work,
check crank position sensor, run scanner for trouble codes , some auto parts will do this for free
Sep 27, 2009 | 1991 Chevrolet S-10
Trouble starting Craftsman Lawn Tractor Mod# 917-272350
It is time to rebuild your carburetor paying special attention to the float and seat.
Gasket set is about $30 delivered and gallon can of gunk carb cleaner with a parts basket is $21 at kragen auto parts. takes about two to three hours. Or you can but a new carb for about $150.
Jan 29, 2009 | Garden
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
