Question about Health & Beauty
Norelco SmartTouch-XL razor, stopped working won't charge
I have a Norelco SmartTouch-XL razor. Maybe 50 charges in 4 years (last charge lasted over a month). It just stopped working. I plugged it in, lights light up, no charge. Not sure if it's the battery or something else. Help.
  • Health & Beauty Master
  • 1,625 Answers
It is doubtful that the battery is bad because they dont normally go bad suddenly. Usually, they will degrade slowly and hold a charge less and less before they stop working.
It sounds like you may have a loose connection somewhere. Check the leads from the circuit board to the moto and also the tabs that connect the battery to the circuit board. These sometimes break.
Posted on May 08, 2010
    New Friend:
  • 4 Answers
Here's a reply for the 4601X shaver if LED indicator fails to work after battery replacement: one solution, the voltage regulator part in back of the razor fell off. It's a reddish color item with metal prongs; it must be put back originally where there's a horizontal 'extension' line of the plastic case and the prongs go to the board/connector cord part. Take opportunity to clean the unit with air and lightly lubricate the motor with silicone spray, put it together carefully, tighten screws and slide it to proper voltage. Once done, the LED works and unit gets a little warm-it's now charging properly.
Posted on Aug 13, 2014
Norelco Spectra 8865 XL Razor running slowly
there is whiskers under the heads,you need a small brush to clean them or your owners manual tells you how to remove heads which you can probable figure out yourself.
May 27, 2012 | Norelco Spectra 8865 XL Electric Shaver
Norelco 8894XL is charging to over 100 minutes. According to manual, it supposed to charge only to 100 minuyes. What is causing it overcharge?
I have owned a Norelco 8894xl for over 10 years. My battery meter will show 127 minutes after the razor is fully charged. The battery is not over charged. This is normal and does not indicate a problem. Hope this helps.
Jan 07, 2011 | Norelco 8894 XL Electric Shaver
Philips address in dublin ire.
You can find any Philips / Norelco Replacement Razor Heads for Smart Touch XL and Speed-XL Razors easily on eBay ..
please visit the link below to locate a seller accepts to ship it internationally.
www.ebay.com
Make sure you search it in two brands..Philips or Norelco ..
Believe me it is the cheapest way to find.
Good luck..Regards
Oct 06, 2010 | Norelco Replacement Razor Heads for ...
Razor stopped red light comes on will not charge
mcdevito75 here, If the battery is 2--3 years old it may have to be replaced, battery may not accept a chatge anymore. Look for any appliance repair shop in your area for assisstance. Sometimes with Norelco shavers it pays to replace the shaver over changeing the battery--ies.
Jun 25, 2010 | Norelco Spectra 8865 XL Electric Shaver
My razor appears to have died even though the LED
Usually the batteries last only a few years before needing replacement. Rechargeable batteries are good for only so many cycles so you've done well to go 8 years. You can replace the batteries if you're handy with a soldering iron - I've done it many times. However, with 8 years on the clock you'll probably want to replace the blades too. The batteries are about $10 for the pair (AA rechargeables with solder tabs) and the blade set is about $30 so you're approaching the cost of a new shaver already. Here's a link - you'll need two.
http://www.zbattery.com/NiCad-AA-1000mAh-Rechargeable-Battery-with-Solder-Tabs
Apr 18, 2010 | Norelco SmartTouch 9160XL Electric Shaver
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
Smarttouch xl lock
Keep the on/off button pressed for approx 30sec (or more) until the razor starts
Dec 05, 2007 | Philips SmartTouch-XL HQ9190 CC Electric...
Health & Beauty Logo
338 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
