Question about HP LaserJet 3000n Printer
HP 3000n Laser Color Printer - Paper is curling up when it comes out of the printer. How do I stop that?
    Scholar:
  • 67 Answers
Make sure you've let the printer know what type paper you are using. In the print dialog on your PC, you must choose in the preferences area whether Plain, Photo, Glossy, Cardstock, Envelopes, etc. Such things control the pressure of the rollers in the fuser, as well as it temperature. Too hot will result in curled paper.
Also, make sure you are storing the paper properly prior to printing. It can't be too damp either, or it will curl.
Finally, if all else fails, your fuser may be overheating and need to be replaced. Hope not. If so, look for a rebuillt one online. Much cheaper than new. Good lick!
Posted on May 03, 2010
Hp color laserjet 3000n error 51.2
According to the service-manual, it looks like you have problems with the laser/scanner-unit.
Please foolow these steps
1. Press to continue.
2. If the message persists, turn the printer
off and then on.
3. Reseat DC controller connectors J1010,
J1012, and J1021. Reseat laser/
scanner unit connectors J101, J102,
J5001A, and J5001B.
4. Replace the flat cable.
5. Replace the laser/scanner unit as
necessary.
6. Replace the DC controller PCB as
necessary.
If you cannot comlete these steps by yourself, you have to put the product in for service.
May 15, 2012 | HP Color LaserJet 3500 Printer
I get this error code in hp 1312 error cod 51.23 what can i do i wait your answer best regard
Turn power off. Unplug printer. open and close firmly every door, hatch, panel, and drawer. Verify all toner cartridges are full. Verify that no paper is jammed in the mechanism. Power printer back on.
Aug 20, 2011 | HP Laserjet CM 1312NFI Color Printer
My copies come out curled. Is there an adjustment for that? Brad
Sound more like a paper incompatibility problem. Try another brand of paper, bearing in mind that a laser printer has heating rollers that do tend to put a bit of a curl in the paper.
Jan 25, 2011 | Brother MFC-8860DN All-In-One Laser...
HP color laserjet 3000n error 49.4C02
Thank you for the inquiry.
49.4C02 Error The 49.4C02 error usually follows a paper jam. When the customer closes a door after clearing the jammed media from one area of the printer, the control panel immediately posts a 49.4C02 error. Often, the customer will then power cycle the printer and it will hang at Checking Printer. For the 49 error to occur, additional media must still be stuck in the paper path.
Firmware version 5.005.3 contains a fix that allows the printer to recover and notify the customer of the location of the additional jammed media in the paper path. Customers who experience this issue should update to the newer firmware. This version of firmware also fixes the issue with the printer hanging in Checking Printer.
Since a paper jam is the event that triggered the 49 error, if paper jams continue, troubleshoot as necessary.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 11, 2011 | HP LaserJet 3000n Printer
Is it possible to burn yourself with the paper coming out of an HP LaserJet printer?
No, is not possible. The paper can't be overheated in such manner to burn you because it will turn yellow or brown.
Nov 02, 2010 | HP LaserJet 3000n Printer
Paper is curling when it comes out of printer
either your using a poor quality paper or the heating element of the printer is malfunctioning.
Sep 17, 2009 | Brother HL 5250DN Laser Printer
Paper is curled inwards when it is ejected from the printer.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 20, 2009 | HP Office Equipment & Supplies
Paper comes out in a rolled fasion
I guess what you mean is the paper curls when it comes out. It's most likely that the paper is cold and a bit moist, then once it goes through the transfuser (a very hot module inside the printer that settles the toner onto paper) and with the tensions on rollers, the heated surface expands and causing the paper to curl. And thicker paper will have more effect than normal papers. Try keep storing your paper in a dry location (but without sunlight).
May 27, 2009 | Office Equipment & Supplies
Paper curl
Paper Curl. Does the paper have a curl on the trail edge? (The last part of the paper to exit the printer)
If it is the entire paper replacement of the fuser will likely resolve this.
If the paper curl is on the trail edge then replacement of the upper delivery roller should be done.
Nov 03, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 3000n Printer Logo
308 people viewed this question
Seeker5211
Seeker5211
