Question about Garmin StreetPilot C330 GPS Receiver
Low Battery notice kept coming on
This was while charger was on...I checked fuse, it was ok. I ordered & had a tech install new battery, same problem; I used a friend's charger...same problem..Low Battery! Help
    President:
  • 1,851 Answers
TRY RESETTING THE UNIT - Also - charge the unit over night with a WALL CHARGER - this helped when mine pulled that same stunt. Eventually it went away after charging it over night in the wall. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES Low Battery notice kept coming on - 5770b9e.jpg
Posted on May 08, 2010
Can I over charge my mobility scooter batteries with a pihsiang charger the green light wont go solid
Take the batteries to a battery shop or a Battery plus store have them load test the batteries. Deep cycle batteries are different from normal batteries. Normal batteries are design for max output for short periods of time, Deep cycle batteries are designed for a modest output for long periods of time. My batteries are rated at 35 amp/hr.. Basically a load tester places a load in amps [cranking amps] on the battery. How many cranking amps depends on if there is a voltage drop when you apply the load. I can apply 480 cranking amps before my voltage drops. What i do is load test a new battery of the same type to find out the cranking amps. You will not find a cranking amp rating for aq deep cycle battery but retail places have load testers that read in cranking amps. Use only deep cycle batteries in scooters, garden tracker batteries will not last. If the batteries are ok test the charger. A CHARGER KNOWS THE CHARGE OF THE BATTERY BY BATTERY RESISTANCE. As a battery charges its resistance get bigger. Once the battery reaches a preset resistance the light goes solid. You can have the charger checked by a battery shop. To properly charge a battery a charger will put out 27volts @ 4amps, they can easily test for voltage. Now if the charger is built in there is going to be an external fuse find it, check it. hope this helps
Jun 07, 2012 | Health & Beauty
My dell studio 1737 has gone dead.
For a new battery, we advise that you update the BIOS of your laptop, and open the hardware automatic identification port of your laptop.
When you use it firstly, you need to discharge till 5%, then charge it about 11 hours. Usually, new battery need to fully discharge and charge for three or four times, which can achieve the best performance.
About the new battery, please set the power management of your laptop: Property -> Screen Saver -> power -> Power scheme -> Portable / Laptop -> please cancel about low battery alarm and serious shortage of battery alarm when use the battery.
For some laptops, you could try to close your power management tool to test your new battery.
You could try to take out the battery from your laptop, and put it back again, repeat several times. Make sure that it isn't a poor contact problem between the battery and your laptop.
If the battery works in higher temperature, the battery protection plate will work and the laptop restart program will make a termination order. You can take out the battery, put it back again, and avoid work in high temperature.
In order to avoid some damage to the battery, please note:
Please don't take out the battery when the laptop is in run status.
Please don't pull out the ac adapter frequently when the battery is charging.
Please use high quality and reliable laptop charger, not to use the universal laptop charger.
Are there something wrong with the new battery can not charging?
That's not usually the case. When equipment for the first time to recharge the battery, the instability of the voltage and current may cause the battery charge to 50% (sometimes more, sometimes less), and equipment stop charging the battery.
If this happens,don't worry. You just remove the battey from the equipment, recharge again. First charging a new battery may need several repeated process. Please be assured that this is normal.
Many people have reflected that Dell's notebook haven't recognised and charged the new battery problem. Usually, they solve this problem via BIOS refreshed.
Usually, please connect the battert with the power supply when you can refresh the BIOS. You can download the BIOS program from Dell support website http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=dell+bios+inspiron+6400&cat=sup, automatically installed and automatically restart till to complete. Of course, you could check its use manual in advance.
Or you can visit http://www.batteriescenter.com.au/.
Mar 25, 2012 | Dell Studio 1737 Laptop
10 amp draw draining battery overnight on 99 tahoe
I have done this before, put about a 10 amp charger on the battery. Pull the courtesy light fuse first. Look at the battery charger, it is probably charging several amps, pull one fuse at a time. When the charging amps drops down you found the fuse the controls the problem. I had a car several years ago that someone pulled the seat belt all the way out, somehow it was pulling a load and draining the battery overnight.
Jan 05, 2012 | 1999 Chevrolet Tahoe
I installed a shark audio amplifier on my bike. battery died.I tried a small trickle charger to recharge batt but somehow killed the charger.I disconnected shark amplifier and led lights, then bought...
it sounds like your charging system is out. use your volt meter check the battery charge before you start the bike, it should read about 12 volt, start your bike now, check you meter you should be running about 13.5 volts. rev your bike watch your meter it should spike around 14.5 if your meter jumps up over 15 your reg/rec is not working right, if it drops when you rev the bike you stator is not working. Its always best to replace them as a pair as they work as a pair and bad old part can kill a nice new pricey part if you follow what im saying. the stator is the coil winding that makes a/c power after its made it goes to regulator/ rectifier it's job is take that a/c power and make it d/c (you can only make a/c power and store d/c power) it also regulates the volts around 13.5. see what you got and let me know
hope this helps
M.Woodring
Apr 19, 2011 | kawasaki VN 800 Vulcan Classic Motorcycles
HP pavillion battery icon says (plugged in, not charging) what makes this happen, i am a premium expert on here and have no clue on how to fix this! (NEW COMPUTER) LOL...
It means there is no output from your battery charger. This could be the charger itself is bad. The charger fuse is blown (if it has one) or the wall power outlet in the room is dead. First, check your charger output. You can do this test with a volt meter, another laptop, or a 12v globe and some wires. If that is ok, both charger and wall outlet are ok and the problem is either the battery or the laptop itself. Another possibilty is that it is in fact charging the battery, but the indicator says its not.
Mar 22, 2010 | HP Pavilion dv6000z Notebook
1999 camry battery died. Wont stay charged.
Your battery is dead, and most likely the alternator is not working. you will need to fully chagre the battery in order to properly test it. if you have a battery charger, put it on low 2-5 amps and let it charge overnite.then take it to your favorite mechanic to get it checked out.
Sep 23, 2009 | 1999 Toyota Camry
Charger/power light will not come on when plugged into usb or car charger
Check the FUSE usually located in the plug if so equipped try owners manual. Also check car fuse for short or overload fuse opens, also bad battery replace it, try Mouser electronics lotta techs are ordering on line no min order.
Apr 16, 2009 | GPS
2003 Yamaha 650 Classic No power from the battery or a charger.
At 55 amps you could charge the batteries on the space shuttle. A 2 amp charger is plenty. You cooked the three year old battery so a new one will be needed. Get the new battery then worry about the fuses only if the bike is still dead. The fuses are under the battery side cover if I recall correctly. Look under the seat if not by the battery.
Please rate this solution as a " FixYa ". Thanks!
Mar 24, 2009 | 2003 Yamaha V Star Classic
Kawasaki 19.2V Battery
Danger!!! There is a RECALL NOTICE in effect for batteries and chargers for Kawasaki 19.2v systems. Go to the website and check your model number and they will ship you a free charger, if your model number is affected, RECALL NOTICE
Jan 13, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Garmin StreetPilot C330 GPS Receiver Logo
90 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
