Question about Kenmore Oasis HE 27082 Top Load Washer
Taking the drum out
My washer keeps sucking everything down under the bottom ring from my kids underware to washclothes. so i beem fishing that stuff out but i need to take the drum out to make sure i got everything else out from it.
thanks
    President:
  • Kenmore Master
  • 2,651 Answers
The drum lifts right out on this machine, ( not even screwed into place, but hte the trick is popping themain llid assy, by placing a puttty knife betwent the main top and the front face perhaps 2-3 inches in from each side, after removing the top, the drum should liftright out of the outer tub, ty using a laundry bag for the smaller atore
Posted on Mar 26, 2008
Washer want ring out kenmore
I had this problem on a kenmore affinity if this is your model or others have same problem people don't use net bags for socks underwater pantyhose and they get sucked into the drain and stop the spin cycle it will run but never finish take top off then control front there are stews under the soap dispenser take that out then there are screws on top and bottom of panel in front undo spring around the door rubber in the bottom there is a black hose take off there is a peace of plastic that traps small stuff like above and also whatever u leave in your pockets sooner or later u clog it up clean out and put it back together wall will drain and spin out if not try next step
Jan 05, 2014 | Kenmore Washer Balance Ring 9724323
Hi my washer does not drain properly. I think it used to pump the water out then spin the tub, but now the tube spins slowly when it is trying to pump the water out. Could something inside the transmission...
I would start with the simple possiblities first.
Remove the front cover (look for 2 phillips screws at the bottom of the front cover) Once you pull the screws, pull the bottom of the front cover forward until it disengages the two top retainer clips. This will expose the interior of the machine.
The pump is at the bottom right and has the hose from the drum attached and the other hose goes out the back of the machine.
The pump is opaque plastic and you can see if there's something jammed in the pump ( like a small sock). If it's "sucked a sock" it will jam the pump and will cause the drive belts (under the machine) to burn, stretch and not pump the water out. You can replace the belts by simply reaching under the machine and moving the electric motor a little.
If you've cleared the pump and changed the belts, try running the machine through a cycle with the front cover off and see if you've solved the problem..
with Maytag, this is usually the solution... If you're still not draining, you may have a small clothing article in between the inner tub and the outer tub... this will eventually block the drain on the outer tub and prevent water from getting pumped out..
You can use a straightened out coat hanger with a small hook bent on one end, take the top onf the machine loose (2 machine bolts hold the front corners down and tip it back away from the machine case. This will allow you to take the top cover off the outer drum exposing the space between the inner and outer drums. Take your "fishing rod" coat hanger and fish between the two drums on the right side near the drain hole... Most times you can snag and remove the blockage and pull it out.
Hope this solves your issue.. please let us know if we can help you further ...
Dec 02, 2009 | Maytag MAV2755A Top Load Washer
I have a LG WM2016CW washing machine and there is change (penny,nickle,dimes ect.)stuck in the drum some were, how do i get them out?
You said "stuck" in the drum somewhere? Like under the agitator vanes? You should be able to take the lid off the agitator, it should either clip in or have a screw holding it on, and there you will see the nut, or keeper that holds the agitator on the motor shaft. Remove that clip or nut and you can lift the agitator out of the washer. From there you will see all of the wash drum and should be able to remove any foreign objects. If these "coins" are between the inner and outer tub, then you will have to remove both the top cover and lid, and remove the agitator and the inner drum to get to the outer drum in order to reach these objects. Not a hard job, but it will take you a little while. You could try reaching with your fingers around the agitator bottom and see if you can "feel" the coins or objects and possible use a small brush or stick or popsicle stick to move them out so that you can reach them, Kinda like "fishing" under the refrigerator or the couch. In the alternative, you could enlist four friends and unhook the washer from the water supply and the electric, and turn it upside down and try to shake the coins or objects out the top of the drum. Tilting the machine to one side will let them fall to the cabinet sides and possibly drop out the bottom when it is uprighted. Now I know why Mom always "checked" my pockets before she washed Dad and my clothes. We left a little of everything in there, from time to time. Good Luck with this.
Sep 27, 2009 | LG WM2688HWM TROMM SteamWasher
Item lodged under drum Kenmore HE2 46462
Take the back off the washer lay the drain hose down into a bucket so that the water drains out
Check to see where the main drain hose comes out of the bottom of the outer container
Lay the machine down onto some cushions so that the hose opening is nearest to the floor
Take off the clip securing the hose , place a cloth under the pipe and pull it off
You should then be able to go fishing for the item
Good Luck
Sep 24, 2009 | Kenmore 46462 Front Load Washer
1999 waverunner: does it have a screen under the
You may require a new wear ring for the jet pump, especially if a lot of sand has gone through the pump. I don't know of any screen that protects the jet pump and water intake.
Check for daylight between the pump impellor blades and the outer wall (wear ring). Any water allowed to escape past here will cause a lot of power loss.
Jul 03, 2009 | Boating
Mildew odour from Whirlpool Duet washer.
I've had this problem a couple of times over the years I've had this washer. What caused the odour in my machine was one (or more) of my kids' socks getting stuck in the machine. With the door open, gently reach in and bend the grey rubber door seal back and feel for clothes that have slipped between the drum and the rubber. If there's nothing there and it has been smelling bad for a while, then it's likely that the socks have been sucked into the drain. To clear this without paying a $150 service charge (I did that the first time and watched him fix it in 10 minutes), you'll need to remove the bottom front plate of the washer (there are only three or four Torx -or star head- screws holding it on). Once that plate is off, you'll see a white plastic knob that is the cap of the drain trap. Unscrew the cap and a couple of cups of water will leak out so shove a couple of towels under it beforehand. You should find some long-lost now-rotting socks. The last time I had to do this, I found FOUR socks in there. This also contributes to the 'suds' error message as it prevents proper drainage. I've only had this problem with kids' socks, everything else is too big to get stuck, I guess. Maybe try a laundry bag for the smaller stuff.
Apr 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes keep catching in front ring area
>>A repair man replaced the plastic ring but the gap is still there, ruining several items per load. Is it repairable or a fatal defect?<<
The repairman should check the drum rollers, the guides, and the baffles to be sure the dryer drum is rolling true (round). Also, the replaced ring should be re-checked to be sure it's installed correctly.
Apr 10, 2009 | Frigidaire Dryers
Water pours out from soap/softener drawer at top...
I'm guessing, what with this having been posted nearly a year ago, that this has been resolved, one way or another, but I thought I would post this solution for the benefit of others:
We had this same problem, where water was flowing out from underneath the detergent dispenser. The problem we had was a blockage between the dispenser and the drum, so after taking the console and door-panel off the washer, I removed that black tube from the dispenser to the drum and pulled out the matted-up sock which had somehow made its way there. Good luck!
Jan 15, 2009 | Whirlpool WFW8300SW
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Key in machine
2 things you can do, either remove the sump hose from the bottom of the drum,or take the back off remove the element and fish the key out from there
Jul 11, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
48 people viewed this question
Sal De
fordexpert
Robert Rankin
