Question about Panasonic PT-60LCX63 60" Rear Projection HDTV-Ready Television
Panasonic pt60lcx63 ballast
How do you replace a panasonic pt60lcx63 ballast?
Why red light is on ?
Its the most common poblem with the ax 100-200 projector.Many a times only the ballast requires to be replaced.yet on may occasions both mainboard and ballast requires replacement. its best to confirm with a good known working ax200 and replace first the lamp, ballast and the mainboard.panasonic ax 200 lamps also have failed premature as per my experience.
May 04, 2014 | Panasonic PT-AX200U Projector
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
TV shuts off by itself
I would think a ballast would be easy to change take out old put in new like for like
Nov 07, 2013 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT60LCX63 won't turn on or off, just keeps blinking either red or green
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where,if otherwise Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help to solve the problem...
Aug 05, 2011 | Televison & Video
Panasonic PT-61DLX76-K TV, no picture, red lamp indicator flashes once every five seconds. Bulb looks okay visually. Panasonic says bad ballast I need confirmation and service manual.
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Dec 01, 2010 | Panasonic PT-61DLX76 Television
Panasonic pt-50lc13 it just will not turn on,but the red light is on and the lamp was replace
Is the lamp indicator light flashing? A new lamp may not solve the problem. The known problem with lamp failures is poor voltage output from the ballast,.. a problem Panasonic refuses to correct and they decided to no longer provide the repair part through their supplier in an attempt to sweep this problem under the rug.
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
Jan 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-LB10U do not work lamp ok ballast ok issue is with the power suplly that do not send 15v dc to the ballast need to fix the power supply it send 380 v dc to the ballast but do not have the 15 v...
You have to replace the transistor Q107 on the board ETXM519MBGB
this is pnp type but i can't find it on service manual.So if you don't like to make experiments replace the board.
Oct 21, 2009 | Panasonic PT-LB10VU Multimedia Projector
Where do iget a ballast for a panasonic pt50lc14? already replaced bulb, looking for a ballast. is there a spacific ballast i need?
my recomendation would be save your money, and spend it on a new tv. by the time you pay for it you could of bought yourself a new tv...even though it wouldn't be a 50" you'll be much happier in the long run.........
Mar 02, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Ballast problem on PT-40LC12
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Feb 01, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-60LCX63 60" Rear Projection HDTV-Ready Television Logo
280 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
