Question about Panasonic PT-51DX80 51" Rear Projection Television
Set turned off normally and it wont turn on, just three short red light blinks. Then I unplug it and the turn it on the red light stays on for five seconds then turns off.
Covergence ic short repair 350
Posted on May 06, 2010
My WD-60639 DLP TV won't stay on (it goes off right after it gets on)
You should be getting a light or lights on set blinking in this case, and the set should have a self check if they blink etc---hold menu and input in at same time for more than five seconds and release both, the blinks on the power light should be a two digit code like three blinks, seven blinks which is 37 Let me know what if any code you find.
If you unplugged the set during this time it will clear the errors so you have to try to turn it on again, let it fail and do the check again.
SD TECH
Dec 11, 2012 | Mitsubishi Televison & Video
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
Upon arriving from work today, I noticed that the "red power light indicator" was flashing periodically in intervals. I tried to turn the set "On" but the TV does not want to turn...
unplug set and plug back, the blinking power light is a error code, watch it carefully, a sequence of three blinks, pause and three blinks is the most common, it is SHORT PROTECTION.
Five blinks and a pause and five blinks is short on 140 volt line.
Let me know what you find and I will offer suggestions for you.
SD TECH I am in California
Feb 11, 2011 | Panasonic PT-53TW53 53" Rear Projection...
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My hitachi 50vs69a tv wont turn on and after afew blinking red li
Have you replaced the lamp? Unplug the set remove the lamp and see if it's blown
Sep 20, 2009 | Hitachi 50VS69 50" Projection HDTV
Toshiba 32AF43 problems
bright red with lines left to right? would be shorted crt. shutting off would be normal due to high beam current.
Nov 09, 2008 | Toshiba 32AF43 32" TV
Red blinking led
My 42" Philips LCD did the same red blinking sequence last night. All was seemingly fine after unplugging it for a bit. An online search, though, has me worried that this may be the start of (potentially fatal) power supply issues. Anyone have a clue what that sequence means?
I've got one week left on my 1yr waranty, so I'm a bit concerned! :(
Thanks!
Jan 15, 2008 | Philips 32PF7320A 32 in. LCD Television
Problems turning my tv on, need to try several times
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
May 30, 2006 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic PT-51DX80 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
