Question about GE GSS20IEP Side by Side Refrigerator
Compressor running, Fans are NOT
Eight year old GE side-by-side, Model # GSS25TSR. I replaced the mother board, but no change. Compressor runs and cools, but neither the compressor fan nor the evaporator run. I'm running out of time before my food spoils. Please help.
  • 1 more comment
  • leedeering May 03, 2010
    Thanks, Jack, but I checked the list of covered models, and mine is not among them. I just checked the compressor tank and it is very hot, so I unplugged the refrigerator. I was hoping to keep it as cold as possible, but now I don't know what I'll do. Can you tell me where the relays are located on this model so I can check them? I would appreciate it.
    Lee
    Ok. I found the relay and removed it. Do you think replacing this relay is a promising solution? I'll have to drive the the appliance parts store, about twenty miles away, and if there are other, more likely possibilities, I would really appreciate hearing about them before I go. Any suggestions?
    Thanks,
    Lee
    Thank you. I will give it a try.
    Guru:
  • 1,049 Answers
GE posted a free repair and replacement program on the motherboard and control board due to a known issue, you don't have to replace it yourself. that means you may also be able to get other issues addressed for free at that time if the symptoms are similar.
If you want to try and fix it yourself, check the power on the compressor - I know it cools but that doesn't mean it's working right, then check the Overload and/or relays as well. Maybe current isn't being regulated correctly, this could even be an underlying cause of the high incidence of board failure.
Posted on May 03, 2010
  • 2 more comments
  • NA NA
    NA NA May 03, 2010
    Was this helpful?
  • NA NA
    NA NA May 03, 2010
    Should be a small black box with two copper contacts (tabs that look like you would see on an electrical plug) located near the compressor.
  • NA NA
    NA NA May 03, 2010
    There is a big difference in Relay prices, they range from $4.99 to about $30. honestly, not sure which one that particular model uses, but may be cheaper and easier to replace than to test.
  • NA NA
    NA NA May 03, 2010
    I can't think of anything else. If the relay is bad the compressor could run hot. It doesn't explain the issues with the fan and evaporator directly, but when things screw with power everything else can behave erratically. You know the board is good, the compressor seems to work, so it is the most likely, easiest, and cheapest part to replace and equally easy to take back if it doesn't help.
Ge gsh25jftabb does not get cold
do you hear anything running?compressor or fans?pull it out away from the wall,remove the back bottom panel,check to see if compressor is running,if it is you could have a freon leak and then you would have to replace the fridge,also this has a mother board or computer board same thing,everything goes through it,it's located on the back wall behind a panel,if this is 8 to 10 years and never had the board changed this could be your problem,go here and look at the board,on the bottom left side you'll see the relays,if your board doesn't have all the relays on it that's not the newest board go here to see.
https://www.repairclinic.com/PartDetail/Control-Board/WR55X10942P/4512753?replacedManufacturerPartNumber=wr55x10942
if you need more help with this write back and i'll be glad to help you.but check to first see if the compressor is running,look at the back inside wall of the freezer,if there's frost on the wall then you have a defrost problem,could be a few things so write back and let me know.
Feb 06, 2018 | GE Refrigerators
My gss25lgmfbb is not cooling ..fans are running, compressor is not. interface and display is and off but not fuctioning. How do i check mother board
you will have to gain access to the board i believe this model it is on the back side of unit... if you look closely at board you will see ther eis L1 coming in and then there will be a terminal labeled compressor and defrost so on so on ,,,, jump the L1 terminal to the compressor and plug in if the compressor fires up you have a bad control... this is a common problem with these brands replaced 100's of them......good luck to you hope you get her fixed.....
Jan 03, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My ge refrigerator will not run. Both the
you will need to replace the mother board located behind a removable access panel on the rear lower side by removing 4 screws then unplug old and plug in new mother board,this board contains all the relays that control all the equipment functions
Jan 09, 2010 | Refrigerators
Compressor stopped running in GE GSS25KGMC WW side by side. Fans run. Is there an inline fuse to check? A circuit breaker anywhere? The unit isn't that old.
Remove the main control board , and look on the soldered side , behind the small black boxes . You will be looking for a " bullseye" which is a pin , where the solder has become unsoldered around it . If you find it , resolder and it should work . If all solder joints , behind the boxes look ok , then replace the board .
Nov 26, 2009 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
My refrigerator is not running, but the light is
I believe we need to inspect the mother control board on the rear of your refrigerator for burns or signs of heat damage. The board part number is WR55X10942 and they are usally the problem when the lights are on and the compressor or fans are not running. Sea Breeze
Aug 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor not working
Why did you change the mother board? Was the compressor working before the change? If it was, then you need to check the new board and see if there were any wires that need to be cut when it was installed. If it wasn't running before the board change then you might try the overload on the compressor first. Also it should be checked with a compressor checker to determine if the comp is at fault or not
Sep 06, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ge side by side model # GSS22JEMD BB
YES see if you have 12 volts dc at the evaperator motor if you do then the motor is bad if you do not then the mother board is bad and ge recomends in this case to also change the fan motor at the same time
Apr 17, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
GE GSS20IEP Side by Side Refrigerator Logo
75 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
