Question about Goodman CLQ36AR49 Air Conditioner
Ac won't start, fuses fine - Goodman CLQ36AR49 Air Conditioner
    President:
  • 1,469 Answers
A lot of things might cause it not to start or come on. In other to know exactly where the fault is rom, you will need to do a all round checking of the air conditioner.
The answer is a little bit long for me to type it out. I will give you links to guide you on what to do.
ehow.com/how_4873618_repair-air-conditioner-wont-work.html
or
inspectapedia.com/aircond/aircond15e.htm
or
inspectapedia.com/aircond/aircond1123.htm.
Good luck.
Posted on May 03, 2010
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Whirlpool matermind window AC shows error code F2 when power on and won't cool. Sometimes it starts up perfectly fine.
F2 ---for me its a sensor problem had it done thanks katsaras
Unit -- Whirpool AC Model no. Wasr18k20 1.5 ton split AC
Jul 25, 2012 | Heating & Cooling
The car won't start; lights, ac, radio etc come on but car won't turn over or even click; checked battery cables; put different battery in; still won't start
Check the starter and the starter relay or fuse. A client of mines car was doing the same thing, it ended up being two issues, the starter not working anymore, and a relay that was bad. If I am not mistaken everything should be labeled in the fuse box under the hood and will tell you where the fuse/ relay is for your vehicle
Jun 12, 2011 | 2001 Ford Escort ZX2
I have a 1999 ford expedition and my ac is not cold! I checked fuses and they all seem fine. The ac is blowing but its not cold! How can I tell if its the compressor? Could it just be the a/c clutch...
Hi Kaseyloe, I think that the first thing you should have inspected is the AC gas pressure. If its leaked out, the unit won't run. The clutch of the compressor won't activate. Best take it to a refrigeration company and have them check it for you.
Regards Johngee10
Jun 10, 2011 | 1999 Ford Expedition
Pontiac g6: a/c compressor not coming on. i have checked the 10 amp fuse and the relay worked fine and just stopped thanks
When refrigerant level is low, the compressor won't start, so get that checked at AC workshop and top up the refrigerant to correct level.
May 08, 2011 | Air Conditioning and Heat for Pontiac G6
My 2003 vw bug dies and won"t start when i run the ac on very hot days. sometimes when i"m driving all the instrument panel lights all come on ant then it loses power to aprox 5 mph. I checked the...
ENGINE GETTING TOO HOT AC PUTS MORE LOAD ON ENGINE AND OUT SIDE TEMPERATURE HOT.YOUR CAR TELLING YOU I AM HOT AND NEED A BREAK.MAKE SURE COOLANT LEVEL NOT LOW AND THE COOLING FANS RUNNING WHEN AC GOING IF NOT CHECK FAN FUSE IF FUSE GOOD.YOUR THERMO SWITCH NOT WORKING OR THE COOLANT TEMPERATURE SENSOR AND FAN CONTROL MODULE COULD BE THE PROBLEM IF THE FANS DONT TURN ON.
Jul 15, 2010 | 2001 Volkswagen Beetle
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
TV/DVD COMBO WON,T WORK ON DC WILL WORK ON AC
Have you checked the fuse in the plug on the end of the DC power cord? Just unscrew the end.
Dec 30, 2008 | Sansui CDVD9000
Goodman CLQ36AR49 Air Conditioner Logo
174 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
