Question about Brother IntelliFAX 2800 Laser Fax
The scree reads change drum soon. what does it mean
  • Brother Master
  • 5,124 Answers
The drum is the part of the unit that actually does the transfer of the toner onto the paper. Each toner cartridge does about 2,000 pages and the drum needs to be replaced with the ~6th toner cartridge change (varies with use). Order part DR-250 from Brother or any office supply place that would carry the part.
To replace (wait until print quality decreases or it reads change drum now and stops working). Turn off the unit and let it cool. Close the document tray and the extension and open the top cover. Remove the drum carefully and place it where the toner will not spill. Remove the toner cartridge (if it is still good) and set it aside to put in the new drum.
Wrap the old cartridge up and dispose of properly (not in the domestic trash). Keep the new drum out of the light (keep it sealed until needed) as much as possible. Insert the toner cartridge in the new drum. Then insert the unit into the Fax machine. (Hold by the handles) Close the top cover and the starter sheet should be ejected by the machine.
I hope this helps.
Posted on May 03, 2010
Drum end soon again
My MFC-7420 began to display the message "Drum end soon" so I quickly went out and purchased a new drum. But I decided not to install it until I needed to. Because what does "drum end soon" mean? I thought it would mean that the print quality would deteriorate enough that I would notice the problem. So I continued to replace toner as needed, and pushed the blue cleaning thing down the wire regularly. This went on for over 3 years until *finally* I started having regular print job production problems. I replaced the drum, and the problems were solved. So,my advice is be prepared, but don't replace the drum until you have to -- the message means very little.
Mar 18, 2014 | Brother MFC-7340 All-In-One Laser Printer
Change drum soon
There is an easy reset procedure for this.
1) Open the front cover. 2) Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO". 3) Press 1 to reset the drum count. 4) Close the front cover. Good Luck and Thank You for using Fixya.
Jun 03, 2010 | Brother MFC-7820N Laser Printer
Drum end soon, what does that mean
It means that the drum will end soon. The drum is the piece that holds the printer cartridge. It costs about 115+ dollars at the store, but on ebay, you can get it for a good 60 bucks. :)
May 26, 2010 | Brother MFC-7440N Laser Printer
Change drum soon
Open the front panel.Press and hold the clear button.When "Drum replaced"shows on the lcd panel select yes.The message will be reset.If you experiece any lines in the future you will have to replace the drum catridge.
Mar 12, 2010 | Brother IntelliFax-2820 Laser Fax
Ge profile dryer makes ubbearable noise
the drum bearing is failing or seized or the drum is loose
Jul 21, 2009 | GE Profile Harmony DPGT750EC Electric...
"Change drum soon mean" in my 7820n?
drum and cartridge are two different things. The cartridge is attached to the drum. They do need to either be cleaned with rubbing alcohol and cotton swab. You can try to clean out the connections. But many o require replacement.
Jul 02, 2009 | Brother Office Equipment & Supplies
Brother MFC6800-says change drum soon - is that hard to do?
yes anyone can do this, the drum is the unit the toner fits into, remove as though you were removing the toner cartridge, that the toner all the way out of the drum unit and install the old toner in the new drum and slide back into printer, again the drum unit is just the casing that your toner cartridge slips in and out of
Apr 02, 2009 | Brother MFC-7220 All-In-One Laser Printer
Drum Ends Soon
you need to replace the drumkit, or have it replaced.
Oct 24, 2008 | Brother MFC-9440CN Laser Printer
Replace Drum Soon Message
Read your manual. There is a counter that goes off, that can be reset when you change the drum.
With power on and front cover open press set, then select reset drum
Mar 25, 2008 | Brother MFC-7820N Laser Printer
Brother IntelliFAX 2800 Laser Fax Logo
277 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
