Question about Maytag EPICz Electric Dryer
No start will not power up
  • Maytag Master
  • 43,501 Answers
If you have a gas dryerno start - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
Why wont my computer turn on no lights but fan starts
Replace power supply with an other unit. Power supply differences AT the very old PCs of DOS only and start of windows area. ATX start off Pentium 3 area. ATX with added 4 plug for power of CPU control. New power plug for motherboard of Pentium 4 Birth. Power supply still giving old ata hard drive power only. Addition of Sata power connections/ and now the deletion of the old ata power connections fully from power units.
May 27, 2014 | HP Pavilion Computers & Internet
Bmw 1999 323i has power but no reds on the dash
Does the engine turn over when you try to start it? Or is it just dead silent? Your engine requires a lot of power to start, where the lights on your dash/etc require very little power. It's not uncommon for the battery to be able to power everything in the car but not have enough power to start the engine. Check the voltage at the battery when you're trying to start it. it should be around 12 volts. Try a jump start if you don't have a voltmeter. If it starts when hooked up to another cars battery then your battery is the problem.
Mar 14, 2013 | 1999 BMW 323 Series
Acer one notebook no display and automatic shutdown
= if your laptop computer will not start =
laptops have power supplys that can lock up
the power adapters conectors break all the time
and the batterys are designed to be "con$umable$"
so
- - -- - -- - -power reset - - -- - -- - -- - -
remove the power adapter's wall plug &
leave the power adapter plugged into the computer
but pull the laptop battery out of the laptop.
press the power button just like you are trying to start it
but press it longer, this will drain & reset
the internal supply, now relese the button.
-- - -- - -power adapter only test - - -- - -- - -
reconnect the power adapter's wall plug
press the power button to start it with just the power adapter ,
If the power adapter starts the laptop on its own go down to
"If the computer can be started"
If the power adapter does not start the laptop on its own
leave the power adapter plugged into the computer but
remove the power adapter's wall plug & press the power button
just like you are trying to start it again,
then relese the button
- - -- - - battery only test - - -- - -- - -
unplug the power adapter & put the battery back in
press the power button to start it with just the battery
if the battery starts it on its own go down to
if the battery ALMOST starts it on its own
DO NOT BUY A NEW ONE! it may only be discharged
locate another laptop just like yours and charge it,
and yes this is crazy and yes i am sorry!.
- if your laptop computer cannot start at all -
this can be caused by a bad;
connector ($5-$60), power adapter($5-$60),
battery ($70), internal supply ($40-$90),
or main/mother board ($100-$300)
If the internal power supply is bad or if the
power conector fails at random (intermitant)
most of the cost is determined by how dificult
finding parts and dismantling the laptop is
and if it's external or internal
Jun 05, 2010 | Acer Aspire 5720-6661 Notebook PC
92 grand marquis wont start just clicks when trying to start it battery is good starter is good relay is new. what else could be the problem
Make sure the connections to the battery are clean,and the battery post,no grey,or black residue ,this acts as an insulator.Check the ground connection,to the engine.
Mar 10, 2010 | 1992 Mercury Grand Marquis
DVMRe pro power/start up problem
It sounds like a bad power supply the DVMRE requires a 5.2amp power supply alot of the older models have a lower rated power supply 9 out of 10 times this start up problem can be resolved by replacing the power pack.
Jan 25, 2010 | GE DVMRe-Pro
Problem with the power supply or battery
Have you checked for a Firmware upgrade for the unit?
How old is the unit, it could be a bad battery.....
Aug 07, 2009 | Computers & Internet
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Hp pavilion s3015 goes to sleep at startup and does not recover
Shut down the PC by manually powering it off by holding the power button in until it is off. Start the PC. Does it boot correctly? If so, turn off all the Vista power modes.
Click on Start and in the "Start Search" block type "Power". Click on "Power Options" which should show up above the Start Search area. Put the dot in "High Performance" then click on Change Plan Settings, Change Advanced Power Settings, Click on Power Buttons and Lid, Start Menu Power Button, Click on "sleep" to reveal the other settings - select "Shut Down", then "Apply" then "OK". Close all open windows and shut down the PC using the Start button. Note the power button icon is now RED not amber as before.
Run the PC in this mode and see if the same problem occurs. If so, you have a different problem.
Apex44
Jan 07, 2009 | Computers & Internet
Inverter problem
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
Sep 16, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
Maytag EPICz Electric Dryer Logo
109 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
