Question about Sony VAIO VGN-NR385E Laptop
I need to replace the hard drive in a sony vaio vgn nr385e
Ok, check it out. take off the RAM bay cover. Have the pc on a desk or your lap with the batt. facing you. Start at the far right corner. there are arrows by the screws. take them out moving to the left but stick you the forward portion of the laptop. buy the time you get to the cd rom, you should have about 10 screws. lift up the left corner and there she be. you should be able to pull it out without taking the whole thing off, but its up to you. Enjoy :)
Posted on Jul 07, 2010
  • jtwotheizzo Jul 07, 2010
    so I spoke to soon lol. you have to remove ALL of the screws with arrows. (not the ones in the batt bay) Then pull the bottom off. Now, there is one screw to the right of the drive and one to the left holding down the USB ports. once you remove those, pull back the USB and pull the HD to the left....now your done :P Good ol' sony.
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Sony VAIO VGN-NR385e vista windows crashed
Is it telling you you don't have an OS?Could be HDD has died.That would be relatively an easy fix and not too expensive.See if you can find a working hdd the same type ,pop it in and see if your restore disks will work.
Aug 01, 2012 | Sony VAIO VGN-NR385E/T Core 2 Duo T5550...
Hello my cd rom soednt work. I have a sony vaio vgn-nr358e tried to uninstall the drivers and still no good. thank you
Hi welcome to Fixya.
You can try this link http://support.microsoft.com/kb/929461 if this wont work then it could be the hardware CD/DVD needs a replacement.
Thanks for contacting Fixya. Bye for now.
Jul 16, 2011 | Sony VAIO VGN-NR385E Laptop
Does the Sony VAIO VGN-NR385E have an internal mic? How do I find out? Also, I've heard about people complaining about it not being plugged in internally. How do you rectify this?
It appears that this unit does not come with a built-in mic and relies on an external mic being plugged into it for audio input. It is sold as a low-end or "Budget" machine and doesn't have many "bells and whistles".
May 26, 2011 | Sony VAIO VGN-NR385E/S Core 2 Duo T5550...
Sony vaio VGN-NR385E laptop battery not working
give your battery to compny shop if it is in warnty they will chang your battry. if not give for repair it
Aug 24, 2010 | Sony VAIO VGN-NR385E Laptop
My son accidentally delete our sony laptop dvd
Go to a Google search web page and type in Sony Vaio NR385E/W optical driver
You should see a list of down loads available
Jul 11, 2010 | Sony VAIO VGN-NR385E Laptop
The left button of Mousepad(one on laptop, but not touch pad) is often not working and sometimes need to press hard. Model VGN-NR38M, Sony Vaio. please help
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .
Jun 26, 2010 | Sony VAIO VGN-NR385E Laptop
Left mouse button of Sony VGN-NR38M (nt touch pad) is not working often, and some times need to press hard, please help
mcdevito75 here, Bring laptop to Staples, Best buy for testing, sounds like that key could be hanging up. maybe some sort of oil needed.
Jun 25, 2010 | Sony VAIO VGN-NR385E Laptop
Sony VAIO VGN-NR385E Laptop Logo
871 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
