Question about Canon PIXMA iP4000 InkJet Photo Printer
Fax documents face up or face down - Canon PIXMA iP4000 InkJet Photo Printer
  • Canon Master
  • 5,475 Answers
Fax documents should be placed as you would any document to be copied or scanned. Face down for manually placed documents. If you have an Automatic Document Feeder, the pages go face up.
I hope this helps.
Posted on May 03, 2010
Testimonial: "Thanks!"
  • Cindy Wells May 03, 2010
    You're welcome.
When faxing documents on a Brother 525 fax machine do you put the item Face up or face down
If you have a Brother FAX-525DT, then place the document face down with the leading edge (top) down. The scan unit is on the bottom of the paper path for documents. The manual for the unit is available from Brother's EU division's support. The direct link is http://www.brother.com/pub/eur_fax_doc/fax515_525dt.pdf . The picture for how to position the document to be faxed is on page 55 (page 65 of the PDF).
I hope this helps.
Jan 27, 2016 | Brother Office Equipment & Supplies
How do I place documents in fax Machine Face up Or face down
on my fax machine, hp brand, the item is placed in face down.
this should apply to other brands.
Oct 15, 2014 | Premium New Brother LC61 Series Combo Pack...
I am trying to fax on the 6170 do the sheets face up or down?
If you are sending fax using the scanner bed, your original document should be placed face down. However, if you are sending faxes using the automatic document feeder, original document should face up.
Jun 15, 2011 | Lexmark X6170 All-In-One InkJet Printer
on top of the printer when you put the page in, it should have a small picture description of what side to put down or up.
Apr 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
In what direction to you put in the paper when sending a fax? Up or Down?Front or Back? Thanks
Up or down doesn't matter much, as the recipient can always turn the printout around :) But generally putting the documents upside down will make the fax scan the top of the page first.
As far as front/back is concerned, it depends on the construction - if you look at the document feeder you will see a symbol of a sheet with a corner bent, showing the back side. If there are stripes (symbolizing text) on that corner, you must put the document(s) face down; if the stripes are on the rest of "sheet" - put them face up.
In your case most probably it will be face down. You can always check that, and the quality of document scanning (whether the document is not too light for example) by using the "Copy" function of your fax.
Dec 21, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
When faxing document on the hp 1050 fax machine does the document you r faxing go face up of face down?
Your manual can be found here: "http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=424230&lc=en&cc=us&dlc=en&lang=en&cc=us"
The simple answer is face down.
Dec 19, 2009 | HP 1050 Plain Paper Inkjet Fax
How to fax (face up or face down)
If you put the document on the glass surface, your document should be face down. If instead you use the automatic feed on top of the machine you should place your document face up and the top of the page inside he feeder.
Hope it helps.
Aug 28, 2009 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA iP4000 InkJet Photo Printer Logo
381 people viewed this question
old marine
old marine
