Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Water is leaking into the bottom of the refrigerator
I have found water in front of my sub zero. So I looked inside and in the bottom and on the drawer is water. Is that from humidity getting into the refrig? Solution?
I have the same problem - did you ever get a solution?
Posted on Sep 25, 2010
Why is Water leaking out of the bottom outside corner of my sub zero fridge
I would guess your drain is clogged and leaking. Without a model number I can't instruct you where to look and correct this issue. Good Luck
Aug 12, 2014 | Sub-Zero Refrigerators
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
My side by side subzero is leaking water. The water is coming from under the unit and pouring onto my floor. Thinking it may be a loose water connection for the ice maker and water dispenser. I need to...
I just had this problem with my Sub Zero, water leaking on the floor and fixed it. Take out all the bottom drawers and look on the back wall. You will find a drain hose. Boil some water and using a turkey baster force boiling water through the hose till it drains freely. Mine also had a build up of black mold so I also flushed some bleach down tilll the black was gone. Hope this helps!
Jun 29, 2011 | Sub-Zero 661/F Side by Side Refrigerator
I have a Sub-Zero 550 bottom freezer Ref. It is leaking water all the way back & center beyond the drip pan. I have disabled the ice maker by removing the ice bin and it is still leaking water. I...
There is usually one hose and it could have been moved so its not in the pan any more, you should be able to see it near the pan, from the front with the grill removed, use a coat hanger and hook it back into position, if the pan is over flowing, than that's another problem
Jun 26, 2011 | Sub-Zero Bottom Freezer Refrigerator
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
362 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
