Question about Traxxas T Maxx 3.3 Monster Truck
When the car is turned on and the remote control is turned on the throttle, brake, and steering will not work. The truck starts and idles fine. This happened after i crashed it pretty hard after a jump.
  • 748 Answers
Hi
You have lost battery power to the receiver. Check the wires from the battery to the receiver, check the battery while you're at it. Good luck
Posted on May 05, 2010
2001 impala 3400 low idle issue only after warm-upafter
Power steering switch may be bad . The switch idled up the throttle when steering is applied. The Idle Air Control may be bad or clogged causing low idle.
Oct 06, 2017 | Cars & Trucks
98 freelander stalling fault
Explore the problem to see if its the power steering, or physical steering or engine:
Does it stall when its in neutral and you go to full lock?
If so its the power steering, or the engine isnt ticking over fast enough to generate the extra pump pressure needed when on full lock. Check pump belts are good and tension is correct. Then buy a used idle valve and swap it out.
Also do basic checks to see if wheels are catching on some part of car. Jack it up so front wheels are off ground, on full lock in neutral do the wheels turn freely, or catch on something? Slowly lower the vehicle down and check same as you do it. When its down put it in gear and see if it stalls.
Dec 15, 2013 | Cars & Trucks
1998 mitsubishi galant revs high then low when idling. runs fine but it sounds horrible.
that is your idle air control valve. it is located on the throttle body next to the throttle position sensor
Dec 15, 2012 | 1998 Mitsubishi Galant
Car stalls after turn or idle
Q; Is your service engine lamp on? This vehical has a power steering pressure switch,witch helps your engine maintane idle at parking lot monuvers. its next to your power steering pump.you can check if it works by starting your engine and let it warm up. then without tuching your gas pedal turn your steering wheel slowly , the engine should maintane its idle. if this works and your service eng. soon is not on then try cleaning your throttle plate. A dirty throttle is alot of stalling causes with all vehicals.
Jan 18, 2012 | 2000 Ford Focus
What would cause my 2005 colorado to idle really low and if i stop at a stop light or make a sharp turn it dies what could be the cause
Hello, if your check engine light is not on & the Colorado does not have a P0506 error code....
Check every connection on the air intake between the MAF sensor and the throttle body for vacuum leaks...Remove and clean the IAC (idle air control) & the MAF (mass air flow sensor)
Do not use brake cleaner on the MAF sensor, you can purchase MAF sensor cleaner at your local parts store....I hope this helps.
Aug 25, 2011 | 2005 Chevrolet Colorado
Truck will start fine but if i drive it to say
Sounds like a problem with the idle air control valve on the throttle or an air leak into the inlet manifold. When the engine is cold the temperature sensor informs the ECM that the engine needs a richer mix to get started and to keep running. Once the engine is warmed up and the coolant sensor informs the ECM of that fact, then the fuel/air mix s set to the normal leaner balance. When you stop the hot engine and restart it the ECM is still seeing a hot engine and the idling is now very dependent on the idle air control valve for maintaining a sufficient running mix. If there is an air leak into the air ducting or inlet manifold the hot air under the hood will sucked in first. The ECM cannot sense this un-metered hot air and so the fuel mix is tool lean to fire. If it is the IAC there is an additional diagnostic to confirm if it is at fault. When the engine is running and the truck is stationary do you notice that when you turn the steering wheel (engage the power steering) that the engine badly falters and drops in revs for a second or two. If this is the case it looks like IAC valve is not functioning properly. To fix: 1) remove the air ducting from the front of the throttle and clean the throttle interior and plate until like new. 2) locate the IAC, its often on the throttle body and is a small device held on with a couple of bolts with an electrical connection to it. 3) Disconnect and unbolt and again clean thoroughly Check the two ports on the throttle body exposed by the removal of the IAC and clean these. Reassemble and it should work OK
Jul 16, 2010 | 1993 Dodge Dakota
2001 dodge dakota stalling when coming to a stop
While driving, the Idle air control valve (IAC) fully retracts and you control airflow with the gas pedal. When you come to a stop the computer extends the IAC to let air bypass the throttle plate and maintain idle speed. If the IAC is sticking it sometimes cannot compensate fast enough to avoid a stall. The problem is aggravated by the Air conditioner clutch cycling on while stopping. You don't mention the check engine light so not likely a sensor. If you have a OBDII scanner with live data available you can check the Throttle position sensor easily. You are looking for a smooth change through the range as you press and release the gas pedal. Or use a voltmeter to see the TPS. Measure resistance with engine off or voltage (0 to 5 volts) with ignition on. It should move smoothly through the range.
Another easy test. Park brake on, in gear (if an automatic transmission) at idle, load the engine by turning the steering quickly to the end and see how quickly the IAC recovers. Clean or replace IAC and while in there clean the carbon off of the edges of the throttle plate.
Mar 16, 2010 | 2001 Dodge Dakota
My trx 3.3 idles fine but when you turn the remote on it takes off
you either need to adjust your servo or your idle screw on your controller. when you turn your remote on, it's opening up the throttle causing it to take off. turn on your remote without starting it and if you cant get it to the idle position with the trim screw on the controller, adjust your servo linkage so that it does.
Jan 15, 2010 | Traxxas Rc Revo Nitro Monster Truck
High idleing problem
try and replace (or even just clean off) the idle air control motor it builds up with carbon often its located on the throttle body..u can clean it with carb cleaner or even brake parts cleaner it can be expensive to replace at parts stores but maybe a junkyard one will work too
Sep 26, 2008 | 1994 Oldsmobile Cutlass Ciera
Traxxas T Maxx 3.3 Monster Truck Logo
215 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
