Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Won't start. nothing. i checked the cord with
Won't start. nothing. i checked the cord with another appliance. is there a fuse inside?
  • 198 Answers
Not sure about the fuse, but there may be a reset button the motor. it works like a circuit breaker if the motor gets overheated.
Posted on May 04, 2010
  • maurice_rodr Aug 10, 2011
    where do i find the reset button and fuse?
Won't start
Check alternator fuse , it's should be a high amp fuse . Question is did you give some one a jumb start , this could happen , another thing to check is your ignition fuse and your ignition switch , but first check all fuses . Including the big once under the hood and inside the car . Good luck and I hope this helps
Jan 15, 2013 | Cars & Trucks
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
My black and decker food processor won't start
Without your model number, I can only provide generic answers.Here are some common causes of a completely non-working food processor:
  • Broken power cord (plug). If you are in the habit of yanking on the cord instead of pulling on the plug to unplug the device, eventually the wires in the cord will break right at the plug. Hardware stores love this bad habit; they get to sell lots of replacement plugs. Sometimes if you push or bend the wire right at the plug you can get it to work momentarily.
  • Broken power cord (at device) Sometimes the cord gets twisted or turned too tightly where it goes into the appliance and breaks right at the strain relief. Sometimes if you push or bend the wire right at the strain relief, you can get it to work momentarily. To repair this, remove the bottom plate from the food processor, unplug the terminals at the ends of the power cord wires (note terminal has the ribbed wire and which one has the smooth wire). Remove the strain relief (this is not easy - usually you have to squeeze it with a large pliers and push it to the outside of the appliance. Cut the wire at the break, then strip the ends. Run the cord back inside the appliance and crimp new terminals on the ends. (Alternate: leave internal wiring intact, and use UL approved splicing connectors to attach the power cord to the wires inside the appliance. Make sure the wiring does not interfere with motor ventilation, mechanical parts or reassembly of the bottom plate.) Make sure the neutral (ribbed) wire goes to the original neutral connection. If the shortened cord is not long enough for you, you can buy a replacement lamp cord. Be sure it is 18 AWG wire; 20 AWG is too small for the current (a heavy-duty unit - 10A or more - should have a 16 AWG cord).
  • An internal breaker or thermal switch is tripped. Look for a red, black or white reset pin on the motor (not all models have this). If you find one, push it in. If you feel a soft click when you do so, it was tripped. Trips are caused by using the appliance too long or too hard without allowing enough time to cool. Repeated trips may indicate a bad breaker, an internal short or bad bearing in the motor causing overheating. Some units have a thermal fuse (may be a silver-colored cylinder with tapered ends) in the wiring or built in to the motor.
  • Dirty contacts in the control switches. This is especially common if food has spilled over the pushbuttons. In really bad situations, you may have to disassemble the switch unit (often requires unbending crimp tabs on the switch shell) to hand-clean the contacts. It may be possible to fix it with copious amounts of contact cleaner. Check online to see if replacement switch units are available for your model.
If you know how to use an ohmmeter, start your tests by checking for continuity in the power cord, the motor and the switch unit. If you have a model with an electronic micro-controller, add this information; you may need additional troubleshooting directions. SAFETY REMINDER: unplug the appliance before performing any service on it.
Oct 03, 2012 | Refrigerators
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
Dryer want start come on or nothing
If the dryer won't start, then the safety fuse is usually the culprit. Remove the rear panel to access the fuse. Here is a link to the part you need.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-dryer-thermal-fuse-item-number-ap3132867.aspx
Nov 16, 2011 | Whirlpool LER4634J Electric Dryer
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
1,270 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
