Philips tp3267 c102 i had this tv and it fell on its face and scratched up the tube.I then replaced this tube with a sony tv tube.the tube worked fine but it was upside down. i then flipped the tube and it was right side up but the words were backward. how can i solve this problem.
    Scholar:
  • 70 Answers
I would use a tube from an identical unit. The voltages on the yoke connections can be different from different manufacturers. Otherwise you will need a spec sheet on both tubes from the manufacturer. If you can get the service manual the pin out of the tube should be in there. Hope this helps.
Posted on May 04, 2010
Testimonial: "i have learned from experience that you cannot fix a very scratched up tube thank you. your information has allowed me to use another tube. "
My sony want work on u tube
Reset your tv to factory default and start set up from scratch, that may remedy the issue
Jun 17, 2015 | Sony BRAVIA KDL46EX720 46 Inch 3D 1080p...
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
My philips plasma tv fell off my stand and smashed the screen. there is sound coming bu no picture. the glass inside is smashed but nothing has run out of the screen. can it be fixed?
Yes it can be fixed most certainly. You have broken your Plasma screen and most certainly scratched your filter glass with the broken screen glass inside. Depending on where you bought the TV, and whether you have a cover plan, you may get the Tv screen & Filter replaced under accidental damage. If the TV is still under warranty and you dont have a cover plan, you may find the repair will be refused. If so, you could maybe buy the same tv off ebay as repairs or spares and fix yours.
Feb 16, 2010 | Philips 42PFP5332D 42 in. Plasma...
I have 9P6040CI but i can adjust the TV color. The picture is to orange and to dark
This set needs a complete coolant fluid change. This is very common for Philips projection TV's. Each tube and lens assembly will have to be pulled and the fluid changed. The fluid is put between the lens and the face of the tube for cooling the face of the tube. This normally runs in $300-$400 range. It can be tricky. Convergence can really be messed up if not done properly. Have a repair shop check it out for you. Thanks for using fixya and please take a moment to rate this responce.
Nov 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
I have a Philips Magnavox 9P6040 C102
Yes the coolant in the CRts need replacement. You can get the Phillips CRT Coolant repair kit at the following link which contains the coolant and instructions.
http://servicemanuals.vstore.ca/
Aug 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a rainbow of color about the screen. The TV fell out of the stand and now the color pattern is messed up. It fell face down.
sounds like a degaussing (magnetizing) problem.could be that the posistor inside the TV set got loose when the tv fell down. If you have experience soldering electronic components, you should be able to fix it by re-soldering. Otherwise, call a tv tech to do it.
Jul 15, 2009 | Sony KV-27V42 27" TV
Magnavox projection tv model 8P6044 C102 is very
The CRT fluid is cloudy and should be replaced. Goto www.TvRepairKits.com. They have a kit to do it yourself.
Ed
Jun 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Sony Triniton xbr
The continuous blink code indicates some failure in communication between the computer in the set and the big signal-processing chip that controls most of the TV's video functions. Since the set fell, it's probably due to a either cracked circuit board or a broken picture tube.
If the board is cracked, it might repairable if the broken circuit traces can be found and patched. If the tube is broken (because the shock of the fall cracks the glass neck of the tube and allows air to leak in), it's time to replace the TV.
There's really nothing you can do on your own to fix this. Your best bet is to see if a professional can come out and give you an estimate. (Or use this as an excuse to get new flat-screen which would take up a lot less room!)
Feb 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
