Question about Philips 42PFL5332D 42 in. LCD Television
Several buttons on my sky-remote change tv to chanel'0'
  • 138 Answers
Contact universal remote and see if they can give you a code for the remote 919-573-7854
Posted on Aug 20, 2008
Whenever I change a channel on my Sky/Hd box the T.V changes to Freeview
Have you tried pressing the button that says 'sky' on top of the remote controle before changin chanel? it could be something as simple as that, if that fails id advise you to ring sky
hope this helps
Mar 03, 2011 | Sky Toys
I need the code for my LG TV model number 42LD490-Z8so that I can programm my sky remote can you help? Thanks
hiya m8, just bought this tv too the code is 0206 press the tv button on sky remote then press & hold select & red button untill remote led flashes twice, then press 0 2 0 6 then tv button on sky remote hope this works for you
Jan 11, 2011 | Televison & Video
Sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Aug 16, 2009 | Televison & Video
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
SKY REMOTE
Press TV
Press and hold Select & Red until the LED blinks twice
Press TV
Type in code 0 0 6 0
press the Power button on the remote, if the TV turns off press the select button and everything should work, if the TV stays on press the TV button on the remote then the Power button again, keep doing this until the tv turns off, when it does press the Select button and all should be ok.
Feb 01, 2009 | Toshiba MR120 Remote Control
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
Tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Philips 42PFL5332D 42 in. LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
