I have a HP desktop with Windows XP. I have 2GB of Ram,ddr2-533MHZ with 1 GB in each slot and I can't add more RAM.I have a INTEL Pentium 4HT Tech Enabled3.0GHZ CPU. My machine is getting slower and slower. I have checked for Viruses and registry errors. Is there a different CPU that I can install that will make my machine quicker and more responsive?
  • Mike Mattis May 03, 2010
    Your suggestion sounds good and makes a lot of sense. Thanks for the good help.
    Mike
  • 560 Answers
INTEL Pentium 4HT Tech. maximum speed:
Northwood (130 nm) - up to 3.2GHz
Prescott (90 nm) - up to 3.80 GHz
Here is the link for more details:
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Pentium_4_HT
http://ark.intel.com/MySearch.aspx?HyperThreading=true
(Look for Northwood or Prescott)
Let me know if you need further assistance.
Posted on May 03, 2010
  • Liza Halbrook
    Liza Halbrook May 03, 2010
    Although, I would suggest to just delete/recreate all partitions, reformat your computer and do a fresh install. Some viruses and worms can hide from your anti-virus making it hard to detect and remove. Install only the applications you really need.
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
Fujitsu v700 4 gb memory will not boot
You don't say if the Notebook is 32 or 64 bit.
If its 32 you may have a problem uprating the RAM more than be handled.
Aug 03, 2017 | Fujitsu LifeBook V700 Notebook 15.4...
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
Oct 10, 2011 | Intel Computers & Internet
I have an HP Compaq Presario SR2011WM PC Desktop Intel Celeron with 512MB RAM. Its too slow, what should i do? Can I upgrade the RAM to 2GB? Thank you.
2 GB (2 x 1 GB) Speed supported PC2-4200 MB/sec Yes, you can add memory:
2 GB (2 x 1 GB) PC2-4200 MB/sec,240 pin, DDR2 SDRAM
2 GB (2 x 1 GB)= 2-1 GB. modules for each slot, for a total of 2 GB.
Make sure that yor run the defragmenter:
How to use the Windows Defrag tool:
To start Windows Defrag, double click on the "My Computer" or "Computer" Icon on Desktop or in Start Menu.
Next Right click on the "C:" drive (Or the drive you wish to Defrag) and select properties from the list that appears...
From the next menu select "Tools" and then "Defragment Now"
The Disk Defragmenter screen will now appear, Click on Analyze. This will check your drives and will only take a few seconds. If your result shows a lot of red like mine (see picture below) then click on "Defragment" to continue) Be warned this may take several hours, so don
Feb 26, 2011 | HP Compaq Presario SR2011WM PC Desktop
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
I'm wanting to add ram memory. Will a Micron 2GB PC3200 DDR-400 ECC Reg ram work? Thanks! Harold
I dont think it will.
It is the right type and speed, but it says your maximum module size is 1 GB.
So you will need 2x1GB sticks for a max of 2GB
http://www2.dealtime.com/xPF-Medion-Desktop-with-Intel-Pentium-4-Processor-530-M3-Composer-5100
Aug 03, 2010 | Medion M3 Director 5100 PC Desktop
Manufacturer specification states that this desktop(motherboard chipset Intel 865 GV) is capable with dual chanel memory..but in CRUCIAL.COM it shows max memory for this desktop is 2 GB, i was just...
Dual channel memory means DDR2 RAM, it is one of the latest technology in RAM. You can use two RAM but performance will be very similar to 2GB only since
Apr 23, 2010 | Dell Dimension 3000® Pentium® 4...
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
