Question about Panasonic Lumix DMC-LZ2 Digital Camera
Lense is not closing
I happen to drop the cam n so the lense is not closing
  • 466 Answers
Possibly the drive train is damaged and you'll have to bring it to the repair shop. But maybe you can fix it yourself: see the various cases and instructions here.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 03, 2010
I dropped the camera and batteries come off and the lense frizze
well ... either get it to the authorized repair center or get a new cam. drop damage is always heavy on the cam and this needs to be inspected by a qualified technician. but beware - repair might a bit less than the new camera would...
Jun 15, 2010 | Kodak Easyshare M381 Digital Camera
I dropped my camera and now its lenses will not close
well if you try and fix it, you may need a new lense, and the prices may run close to the price of a new camera, so you might as well just get a new one and keep the old one for parts, just in case you drop it again ;)
Oct 12, 2009 | Nikon Coolpix S210 Digital Camera
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Turn the power off and on again
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera will shut off then the shutter will close
Yes it could. It is possible a small dirt get on the side of the lense and it prevents the lense to close all the way in. Clean it up and while turning the camera off, push the lense in. Not too hard. You might have to repeat the step a few times. Do not drop your camera, if you did make sure you clean the sides of the popped off lense. If they did not help, some mechanical part of the lense is shifted or broken.
Good Luck
Jun 08, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Dropped Sony Ciber-shot when lense was extended. Will not fully extend or retract now. How do I remove lense assembly to reset position.
sir,
open your camera,beside the cam part u can see the small gearbox, un screw this part and disconnect it from the base, then slowly turn the lense assy to both side carefully, dont give force. if the lense assy becom loose, fix the gear unit give a 3volt to the motor bring the cam to retracted position,then fix whole unit, it will work properly
thanx,
gulshanclt
Sep 03, 2008 | Cameras
50mm C lens issue
From your description, Yes. All RB67 lenses have common problems, usually sticky blades. Since there are 2 sets of blades, (shutter and aperture), the shutter blades may be contaminated with oil/debris
Apr 19, 2008 | Mamiya RB67 Pro SD Medium Format Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
109 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
