Question about Panasonic KV-S2046C Pass-Through Scanner
Getting a U11 error even though the paper went
Scanning multi-page document and it completes but at the end I am getting a U11-11000000 error even though the paper went through. RTIV is giving me a paper jam error error telling me to open the door and remove the paper. There is no jam.
Thanks!
remt23c
  • 78 Answers
SOURCE: Out of paper :CDT009 Load mroe paper to continue scanning
on the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Posted on Oct 15, 2007
night71
  • 328 Answers
SOURCE: Panasonic Hi-speed scanner
I am not sure if you have the manual for it so here it is just in case.
http://service.us.panasonic.com/OPERMANPDF/KVS2026C.PDF
Since there are many steps to opening it to clean, the problem may be reassembling it. You can also unplug it and leave it off for 30 minutes to reset its internal memory. You can also press Start and hold it for 5 sec and do the same with the menu button. If after trying this, your machine does not reset, let me know.
Posted on Nov 18, 2007
ctf1800
  • 4402 Answers
if your positive there is no paper and you have unplugged, you can take canned air and spay it out otherwise you have a bad sensor
Posted on Dec 12, 2007
  • 16 Answers
SOURCE: Persistant error: "Document remains in scanner. Open door and remove document."
I get calls about this all the time. The most common reason for this is the shiny reflector for the Ending Sensor is dirty. It is best to clean this with a cotton swab and a few drops of rubbing alcohol.
Although it is possible that one of the sensors has gone bad. The Panasonic User utility is very basic, but if you have access to the Service Utility it will help pin-point which sensor is causing the problem.
Out of all the calls I've taken relating to this same issue, only two or three situations have been resolved by replacing the sensor - all the rest have just been dirty.
Posted on Dec 02, 2008
mohanchennai
  • 490 Answers
SOURCE: Failed to create a new file
Just check if you have enough disk space in the location where you are directing the computer/Scanner to store scanned images.
S. Mohan
Posted on Jun 13, 2009
Paper jam while scanning multi page document
konica7035 manual service and main board lock damage chip damage
Jun 18, 2013 | Brother MFC-5460CN All-In-One InkJet...
Cannon fax l100 how can I fix this problem
Looks like a document jam as the paper rolled up under the scanner bed.
Do you have the manual for the unit?
It is on line at mypdfmanuals.com. Just google it!
1. Lift the document release lever.
If a multi-page document is loaded, remove
the entire document from the ADF.
2. Lift the paper stack cover and pull it out completely.
Make sure the back end of the cover does
not catch the front paper guide.
3. Lower the scanning platform in the document delivery slot (this is on ththe front of the machine - a small tab you push down.
4. Carefully!!! pull out the jammed document - do not wrench it out.
5. Lift the scanning platform back into place.
6. Inset the paper stack cover (that you took out earlier.
Found it here http://mypdfmanuals.com/dref/815752
Feb 11, 2013 | Office Equipment & Supplies
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
Dr-2050c multi-page document stops scanning after one or a few pages, inconsistently. Feed lever is down in the multi-page position. Feeder tries to separate the pages: sometimes it succeeds. Document...
If the scanner is scanning but stops after a few pages either it could be because of a) There is insufficient disk space (you need to delete unwanted files or direct the comp to store whre there is space) or b) the rubber rollers are not able to separate pages and feed the papers for scanning.(You need to change the rollers)
Jun 08, 2009 | Canon DR-2050C Path-Through Scanner
S. Mohan
Feb 20, 2009 | Panasonic KV-S2046C Pass-Through Scanner
Oct 15, 2007 | Fujitsu fi-5120C
Panasonic KV-S2046C Pass-Through Scanner Logo
404 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
