Question about Sirius Hoods SU3
Hood fan is turning on and off by itself, won't stay on or off.
    Novelist:
  • 145 Answers
What devices in the room were checked. A vent hood will sometimes run on what is called a humidistat, and anytime it senses high humidity it will kick the vent fan on. Check to see if this is the issue, if so and this hasn't happened before try changing the humidistat.
Posted on May 03, 2010
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Won't stay on
You're best bet would be to buy compressed air and blow out all dust and dirt that has made its way inside the receiver. If dust is clogging the fans it will overhead and shut itself off.
Mar 14, 2013 | Yamaha Natural Sound Htr-5660 6.1 Channel...
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
My pc will not stay powered on
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 29, 2012 | Dell Inspiron 530s Desktop Computer...
2001 aurora won't start at all. Hook batery up horn horn sounds and doesn't stop head lights stay on but nothing happens when the key is inthe ingition. No clicking or anything at all. alarm on...
The security system does not disable the starter, it only disables fuel to the engine. In the fuse block under the hood, locate the STARTER relay. Place your hand on this relay and see if it clicks while someone else turns the key to start...if the relay is ok then the starter itself is faulty. Good luck, i hope this helps.
Jul 11, 2011 | 2001 Oldsmobile Aurora
Fan won't kick on a 2006 dodge magnum. want to know where to look for the fuse.
you need to check the fuses in the panel both under the dash and under the hood.if these are okay then you will have to check the fan itself to make sure the fan is working.other things are the fan relay and temp sensor that tell the pcm to turn on the cooling fans,if you are talking about the rad cooling fan.
Jul 05, 2011 | 2006 Dodge Magnum
Broan Allure range hood fan will not turn off, no matter which button is pushed.
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
May 19, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
GE microwave fan not turning off
hello,
what this means is that your oven has develop a partial contact from the wire which supply power to the fan of your oven
what you need to do to fix up your oven is to unscrew the oven then trace the wire down to the fan you will see two wire red and black or white either of this wire is touching the body of the oven this while the fan come up it self then make sure that all wire are well place on there position
thank you and good lock .
Jun 01, 2010 | General Electric Microwave Oven
Fan and lights come on and go off all day long on their own
We installed our Broan-Allure range hood about ten years ago. On three seperate occasions since, the fan has randomly turned on and none of the control buttons would turn it off. After a while it turns itself off. During those same times, when you turned the lights on, they would blink before finally staying on. On each occasion, I have removed the screens and metal underpieces to gain access to the circut board. Once you can see the circut board, remove and replace the 3 Amp fuse that is mounted on the board. (Radio Shack part # 270-1054)...even if the fuse looks good, replace it. Each time this has work for about three years, then it acts up again..
Oct 13, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Sirius Hoods SU3 Logo
692 people viewed this question
Top Sirius Kitchen Ranges Experts
Thomas Perkins
Thomas Perkins
Zeagle
Level 1 Expert
ray gallant
Are you a Sirius Kitchen Range Expert? Answer questions, earn points and help others
