Question about Maytag Gemini® MER6765BA Electric Kitchen Range
How to buy & replace glass top of Gemini stove?
The glass top to my Gemini stove has seen better days. At this point, the wear and tear cannot simply be cleaned away, and I'd like to replace just the glass top.
Where can I buy the replacement glass cook top? I know I can replace it using the user's manual, but I can't seem to find the part!
Thanks,
SOURCE: how do i clean the top of my gemini stove
Use Baking Soda and water and form a paste. Use this to clean the top of your stove. If food is really baked on, you might also consider using a single blade razor to scrape the mess off. Rinse well.
Posted on Sep 21, 2008
DeBruce
  • 145 Answers
SOURCE: Having trouble cleaning splatters off Ingis Glass Top Stove.
Use DeBruce Polish- a true multi-surface cleaner. There is a transfer of particulates from pan to glass surface aided by the heat. The cleaner will remove this "staining". Also use on stainless steel rubbing with the grain- this is the one product that truely cleans the surface. Follow up with baby oil or a stainless steel "polish that is oil based to "seal"the surface.
debrucepolish.com
Posted on Mar 07, 2009
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Posted on Jul 29, 2009
projdoc
  • 2236 Answers
SOURCE: I broke the glasstop of my stove. Can I replace
http://www.partselect.com/Maytag-Stove-Parts.htm
just typ in your model number, and find the part you want on the diagram. you can purchase it through them, too.
Posted on Jul 31, 2009
SOURCE: CERAMIC COOK STOVE TOP CRACKED
the same thing has happend to me... same stove.. Maytag Gemini double oven ceramic top. Can i still use it? is it safe?
Posted on Mar 17, 2010
I cannot relight my stove after a power outage? I have a gemini maytag
Could you please describe the problem you are having a little better?
Is it the stove, the top burners or everything?
Nov 30, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Can a glass top be replaced on a Maytag electric stove?
yes you can Check with AppliancePartsPros.com. You might save 50 or sometimes as much as 250 on a new glass top. They won t even charge you extra for shipping
Oct 17, 2011 | Maytag MER6769 Gemini Electric Kitchen...
I have a maytag gemini double oven stove and I broke the glass cook top, can I order another glass top and replace it myself?
yes you can order it,it's around 200 dollars,and it's a little work to do this,when you call your parts store give them the full model number off of the machine,the part number i found is 5706X371-09 and it's around 200 dollars but 10 models came up and this seems to match all of them but you might have a different color so check when you buy it.
Apr 18, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Back burner doesn't work looking to remove and
These burners are very simple to replace. Is yours a glass top or does it have coil elements on the top of your stove?
Either way, we can direct and guide you to complete this repair.
You will need to contact us with your model number and we can tell you exactly how to remove and replace the element. When you get your parts from us, here at Accurate Appliance & Parts Supplies, we send complete instructions when when we send the parts to you.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST Monday through Saturday.
We hope to get you cooking again soon and look forward to working with you. Thanks, Ella
Nov 21, 2009 | Maytag Gemini 30" Self-Cleaning...
Used self cleaning feature of my electric Maytag Gemini stove. Lower oven glass window in door basiciall cracked into thousnads of small pieces. What did I do wrong and how do I get the stove fixed?
You didn't necessarily do anything wrong. The glass may have been banged at some point and weakened it. The only thing you can do is call an appliance parts store with your model and serial numbers and get them to look up the price and availabilty of the lower oven, inner glass. If you can get the door off the range, and it should come off, it may be more reasonable for you to take the door into the shop where you ordered the glass and get them to put it in for you.
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I need a new glass top for my stove that has shattered. Can you help me find one for a reasonable price? I have found many for $200.00 and Im thinking I should just buy a whole new stove for that price....
much better to buy a new one compare to replace it,coz its so very expensive or buy an electric hot plate more cheaper & practical compare to glass hob.
Jun 23, 2009 | Cooktops
I have recently cracked the glass stove top, if I continue to use it will I sustain more damage and how much will it cost to replace it? We have a Bosch 30x24 glass smooth top with four burners electric....
hi gud day,much better to replae the new one compare to buy the glass top only coz the price of the glass is expensive or little diif for the new one.or if the broken glass is not appected to other burner its ok to use the other burner untill to u want to use.tnx
Feb 01, 2009 | Cooktops
Top of Gemini range
Hello patricialc,
Welcome,
You said, you have the stainless Gemini range and the top is black. I cannot get the top clean. It looks like the paint or the surface is "bubbled". I have tried EVERYTHING and it always looks like there is grease spatters on the top. I have all Maytag appliances and I am VERY disappointed with this stove. If I could, I would take it back...but I keep trying. I let the Maytag stove I had go. It was made in the late '50's, so I could 'update'. What a mistake!!!
The other option is to order a new glass top and have it replaced.
No abrasives!!
Let me know how you do.
Huuum
Please remember to leave a rating!
Jun 29, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag Gemini® MER6765BA Electric Kitchen Range Logo
1,002 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
