Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Change left side opening fridge door to right side opening
On GE Profile refrigerator, I need to change the door from left side opening to right side opening. I know how to move the top and bottom hinges from right side to left, but can't see how the move the handle from one side to the other (unless you just turn the door upside down and change shelves).
  • 1 more comment
  • jcooke927 May 03, 2010
    It does not look like the will install if the door is inverted, but maybe I'm missing something. There's also the case of the GE Profile emblem which would be upside down if I just inverted the door. Don't want to pry it off if it will damage the door.
    The ones I had switched before had the top handle connection on the top of the door also. This one looks like the handle will work from either side, but there's the question of the shelves and that GE profile emblem.
    The model number is PDS22SFSBRSS and unfortunately in the owner's manual it says "handles may not be moved on some stainless steel models". I'll go back and look one more time but I may be out of luck. Thanks anyway.
  • 674 Answers
Will the shelves still work with the door upside down? Also what is the model of your refrigerator so I can get a picture.
Posted on May 03, 2010
  • 2 more comments
  • Brian Niten May 03, 2010
    I can't get a picture but on the refrigerators that I have switched the door from left to right opening the handles screwed in on the top of the door. If you have your model # that would be great.
    On the picture that comes up when I use the model # that's showing on the fixya email it is a double door refrigerator.
    I was able to get a manual online with the serial #. Unless yours has some plugs in the door you can remove to expose screw holes for the handle on the opposite side then you can't reverse it.
    Don't forget to rate my answer. Thanks.
I just got a used GE Profile Refridge and would like to change the door from left opening to right side opening. How would I do that?
Hi. Look carefully at the door and check to see that there are buttons on the side of the door opposite of the hinge. Those buttons conceal the alternate set of screw holes for the hinges. If there are no predrilled holes on the other side of the door then it is not reversible.
That said, If you do locate those buttons, unscrew the hinges from the door, have a helper there as the door will be heavy. Once the door is off, remove the hinges, then move them to the opposite side and reattach the door to the fridge. Put those buttons in the new open holes. J.
Jul 30, 2010 | GE Profile Stainless Bottom-Freezer...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Jun 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge works but doesn't isn't cooling
I will help but you need to confirm your model number. Is your model the one listed above your post? Let me know, Sea Breeze
Jun 19, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
701 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
