Question about E-Machines eMachines Desktop PC
Hard-wired keyboard has gone dead.
Tried to install older hard-wired keyboard, but it did not work either.
Old E-machine (10 years).
Installed 500 MB RAM upgrade yesterday. Could this be related?
    Problem Solver:
  • 17 Answers
Try uninsalling your changes to see if it affects your keyboard. If no help, go back to your original configuration to ensure the system works like before the changes. Then do one configuration change at a time. If it doesn't work, go back and try the other one. That will tell you which one is giving you the problem.
Posted on May 03, 2010
Intel server MB
Find out which BIOS is installed (websearch on server model) then search for Bios Beep Codes for that BIOS. Check what 4-3 4-3 means, you may find it is something simple. If you can get floppy working you may be able to flash BIOS but again you need to know which one
Jul 17, 2013 | Intel n440bx - Server Dual Slot1...
Does my TOSHIBA SATELLITE 2805-S301 have a way to go wireless?
No wireless on this laptop you would need to use a usb wireless adapter
roduct Details and Features Product MPN MPN
PS280U-ELCLOH Key Features Laptop Type
Mid-Size Laptop Use
Home Use Processor
Pentium III 650 MHz Hard Drive
10 GB Display
14.1 in. TFT Active Matrix Operating System
Microsoft Windows ME Weight
7.3 lb. Processor Processor Manufacturer
Intel Processor Type
Pentium III Processor Speed
650 MHz Motherboard Bus Speed
100 MHz Memory Installed RAM
128 MB Max Supported RAM
384 MB Installed Cache Memory
256 KB Hard Drive Hard Drive Capacity
10 GB CD / DVD CD / DVD Type
DVD-ROM Optical Drive Read Speed
8x (DVD) Other Drives Floppy Drive
3.5" 1.44 MB floppy Display Display Tech
TFT Active Matrix Screen Size
14.1 in. Video Installed Video Memory
8 MB Audio Audio Output Type
Sound card Operating System Operating System
Microsoft Windows ME Platform
PC Technical Features Input Method
Keyboard Networking Networking Type
Integrated Network Card Data Link Protocol
Ethernet • Fast Ethernet Modem Modem Type
Modem Analog Modulation Protocol
ITU V.90 Battery Battery Run Time
2 Hours Battery Technology
Lithium ion Dimensions Width
12.9 in. Depth
10.7 in. Height
1.5 in. Weight
7.3 lb. Warranty Warranty
1 Year Miscellaneous Product ID
20789390 Family Line
Toshiba Satellite
Jun 19, 2011 | Toshiba Computers & Internet
Where is the wireless on TOSHIBA SATELLITE 2805-S301
Hi just go this link below:
http://www.user-guides.co.uk/cddownload/Toshiba-Satellite-2805-S301-Windows-7-Driver-CD-Recovery-Restore-Disk-326243.html
Jun 19, 2011 | Toshiba Satellite 2805-S301 Notebook
Need apower supply and hard drive for my compaq presario 1103WM. how old is this unit
It must be up to 8 years old ish as it has XP installed.
17-inch flat screen CRT monitor NEW* Intel Celeron D Processor 3252.53 GHz, 533 MHz FSB, 256 KB L2 cache 256 MB DDR SDRAM CD-RW (48x32x48) 40 GB hard drive 9-in-1 memory card reader 10/100Base-T networking interfaceIntegrated graphics with 64 MB shared video memory *The new Celeron D processors are more efficient than the old Celeron processors. The New 325 D benchmarks faster than the old Celeron 2.7 GHz processor.
Almost any IDE hard drive will work, up to 540Gb and any reasonable power supply should be OK. Check ebay and also google for a power supply.
Hope that helps.
Feb 16, 2011 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
My hard drive copying and pasting is very slow.For 500-700 mb files it takes more than 25 minutes....what should i do to increase the speed?
Im only guessing that its an older PC and your USB connection is probably USB 1? If this is so you can install a PCI USB 2.0 internal card which normally gives you 4 ports which is about 20 times faster. Cheers from Scott and please vote ........bout $10 - $15 at most i think at any good PC shop
Feb 08, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Machine just stopped working. dead
Hi
If the machine is less than 4 years old there are reset buttons on the outside edge of the boiler. There are 2 wires going to 2 thermostats. In between the wires on the thermostats are reset buttons. 1 on each thermostat. They are hard to get to but they might restore you machine. if not it could be your PCB board.
If its older than 4 years there is a reset button on the back of the boiler with just 1 thermostat. Reset button between the wires again.
Jan 02, 2011 | Saeco Vienna SuperAutomatica Coffee...
Mixing Memory
You can't install two RAMs with different MHz on a single motherboard. Sometimes it works but, usually one of the RAM gets busted. This is based on my experience though.
Sep 24, 2009 | Computers & Internet
BIOS not detecing hard drive.
Are you connecting to your machine through usb?, if so that's the problem, the usb is turned on after the bios turn on . Unless the drive is connected through the ide or a sata connector, it's not going to be recognised until the machine boots. You would have to instruct the bios to boot from your usb device. then it should see it after boot
Apr 06, 2009 | Averatec AV7160-EC1 (AV7160EC1-R) PC...
ASUS A7V8X hangs @ splash screen
Just because an installation may hang does not mean the board is dead. If possible I would connect the hard drive into another PC and check for a virus. While in another pc you can remove important data from the drive & copy to a CD/DVD. Than download the drives Mfg's drive software setup program that will run in Dos mode from a diskett. Reformat the drive and install a fresh copy of windows. You might find that is the only problem. Xp does not always install correctly. There may be a software or hard ware making windows hang.
Jan 12, 2008 | ASUS A7V8X Motherboard
The Keyboard not working, MS Wireless, laser, desktop 5000
i don't like the sound of you taking the hard drive out of a old computer and loading it in your new one without reinstalling windows especially with windows XP your choice i guess.
Did you try and couple the keyboard and receiver by pressing and holding the button on the keyboard for a while?
Dec 08, 2007 | Microsoft Wireless Laser Desktop 4000...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
