Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
How do you load the ink. I donot know how to load it to get the cartridge to click.
    Problem Solver:
  • 7 Answers
Drop the ink tank into the printhead and press down on the thumb tab on the top of the tank. You may have to press pretty hard to get the click. It may look as if the printhead is about to break, but it will be okay.
Posted on May 04, 2010
I NEED TO KNOW HOW TO LOAD INK CARTRIDGES IT
The Lexmark 7100 Series User's Guide will give you a more comprehensive guide on how to load your ink cartridges in your printer.
Aug 28, 2011 | Lexmark X7170 All-In-One InkJet Printer
After refilling Lexmark ink cartridge, ink levels donot show full. Reset ink level?
When you refill your cartridge, the cartridge will no longer be able to register its ink level.
Apr 06, 2011 | Lexmark P4350 All-In-One InkJet Printer
INSERT INK CARTRIDGES FOR CANNON IP 2600 I AM TRYING TO INSTALL INK CARTRIDGES AND KEEP GETTING AN ERROR FOR LOW INK i USED CARTRIDGE 30 AND 31? IS IT THE WRONG CARTRIDGE OR AM I DOING SOMETING WRONG?
It sounds like your cartridges are clogged. Follow your manual instructions to unclog them. If you dont have a manual click the link below.
LINK
Also if you click the link below and scroll down under "Got Questions" and Select "Frequently asked questions" It will take a little bit to load but you can select a function for step-by-step instructions.
Please let me know if this has helped you and if I can be of any further assistance.
Mar 29, 2011 | Canon Office Equipment & Supplies
How to how to load ink cartridge load ink cartridge
Here is a link to the main support page for your printer:
HP C3180 Support
Click on the How To link. Then click the link about ink cartridges. Then click on the link that says Replacing Cartridges.
You get instructions with pics and video.
Thanks for using Fixya.
Please take a moment to rate this solution. Thanks.
Feb 27, 2011 | HP Photosmart C3180 All-In-One InkJet...
How do you remove a ink cartridge from a dell v305??? help
Here is a "how to" document from Dell
http://support.dell.com/support/edocs/systems/v305/en/ug/d0e6437.html#replacing-ink-cartridges
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Dell V305w All-In-One R840635AU InkJet...
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    How do I change the ink cartridge on my Dell 810 printer
    Ink Cartridge Maintenance Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
    rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
    To align the ink cartridge:
    1. Load plain paper. For more information, see Loading Paper.
    2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
    In Windows 2000, click Start® Settings® Printers.
    1. Right-click the Dell AIO 810 icon.
    2. Click Printing Preferences.
    The Printing Preferences dialog box opens.
    1. Click the Maintenance tab.
    2. Click Align Print Cartridge.
    3. Click Print.
    A blue and black alignment page prints.
    1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
    1. Press the Scan button scanicoa.jpg .
    The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
    Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
    http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
    Hope it helped.
    Nov 22, 2009 | Office Equipment & Supplies
    How to change the ink in a Canon PIXMA MX310?
    1. Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
    2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
      Note: - Do not attempt to reattach the protective tape once you have removed it.
      - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
    3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
      *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
    4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
    5. Confirm that the ink cartridges are installed properly.
      <1> The ink cartridge is not installed properly.
      <2> The ink cartridge is installed properly.
    6. Fold the scanning unit support and close the scanning unit (printer cover).
    7. Wait until the preparatory operation is complete; it takes about one to two minutes.
    Removing Ink Cartridges:
    1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
    2. Press down on the semi-circular tab to release the cartridge and then remove it.
      Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    4. Fold the scanning unit support and close the scanning unit (printer cover).
    May 27, 2009 | Canon PIXMA MX310 All-In-One Printer
    Lexmark X4650
    Here is how to align your print cartridges
    Using the printer control panel:
    1 Load plain Letter-size paper.
    2 From the printer control panel, press tools , and then press ok.
    3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
    Using Windows
    2 Do one of the following:
    • In Windows Vista, click the windows globe (start button) .
    • In Windows XP and earlier, click Start.
    3 Click All Programs or Programs, and then select the printer program folder from the list.
    4 From the printer folder, click Maintenance Align Cartridges.
    5 Click Print.
    6 Follow the instructions on the computer screen.
    Using Macintosh
    2 From the Finder desktop, double-click the printer folder.
    3 Double-click the printer utility icon.
    4 From the Maintenance tab, click Print Alignment Page.
    5 Follow the instructions on the computer screen.
    If you aligned the cartridges to improve print
    Mar 28, 2009 | Lexmark X4650 InkJet Printer
    Loading the ink cartridge
    Please remember to rate other users who assist you for free :)
    How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
    How to install ink cartridges
    1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
    2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
    Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
    3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
    Note: Push up on the nearest side of the cartridge until it clicks into place.
    4. Confirm that the ink cartridges are installed properly.
    (A) The ink cartridge is not installed properly.
    (B) The ink cartridge is installed properly.
    5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
    How to remove ink cartridges
    2. Remove the ink cartridges.
    Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
